cgal-discuss - Re: [cgal-discuss] Nearest neighbour vertices
  • To:
  • Subject: Re: [cgal-discuss] Nearest neighbour vertices
  • Date: Wed, 1 Apr 2009 11:26:14 -0700 (PDT)
Since I wish the nearest neighbour verticies that are joined to a particular
vertex, will the function Vertex_circulator do this?
Thanks
Michael Balzer wrote:
> Hi disruptive,
> the Delaunay_triangulation_2 in CGAL is inherited from
> Triangulation_2. In this class you find all necessary methods for the
> traversal of the triangulation, such as the method t.incident_faces
> (Vertex_handle v) for acessing the incident faces of a vertex.
> Michael
> On Wed, Apr 1, 2009 at 19:47, disruptive
> wrote:
>> disruptive wrote:
>>> I wish to iterate over a Delauney triangulation by vertex and for each
>>> vertex.
>>> I wish to determine the faces that share this vertex. And then for each
>>> face, I wish to determine the vertices's that comprise this face (one of
>>> which will be the shared the vertex). The latter part can be done.
>>> However my question relates to how best to get nearest neighbour
>>> vertices,
>>> is there a way with the edge function?
>>> Some suggestions for the least complex way to do this would be very much
>>> appreciated.
>>> Thanks
>> Is there a way that I can given a vertex, get the surrounding faces?
>> View this message in context:
>> http://www.nabble.com/Nearest-neighbour-vertices-tp22786442p22831902.html
>> Sent from the cgal-discuss mailing list archive at Nabble.com.
>> You are currently subscribed to cgal-discuss.
>> To unsubscribe or access the archives, go to
>> https://lists-sop.inria.fr/wws/info/cgal-discuss
http://www.nabble.com/Nearest-neighbour-vertices-tp22786442p22832736.html
