cgal-discuss - RE: [cgal-discuss] CGAL 3.4 - Nef_3::intersection() problem
  • To: <>
  • Subject: RE: [cgal-discuss] CGAL 3.4 - Nef_3::intersection() problem
  • Date: Fri, 3 Apr 2009 22:41:26 +0800
Hello Peter,
I've upgrade to version 3.4. I've managed to rebuild the libs with VC9SP1.
I got an runtime error with the following code. The test Nef_3 model is as attached.
typedef CGAL::Exact_predicates_exact_constructions_kernel Kernel;
typedef CGAL::Nef_polyhedron_3<Kernel>  Nef_polyhedron_3;
typedef CGAL::Plane_3<Kernel>     Plane_3;
Nef_polyhedron_3 N;
std::ifstream is;
is.open("./COT1P.nef");
is >> N;
Plane_3 pl(0, 0, 1, -4000);
Nef_polyhedron_3 N1, N2;
N1 = N.intersection(pl, Nef_polyhedron_3::Combine_with_halfspace::CLOSED_HALFSPACE);
// ERROR HERE
N2 = N1.intersection(pl.opposite(), Nef_polyhedron_3::Combine_with_halfspace::CLOSED_HALFSPACE);
I've modified the following lines of Nef_polyhedron_3.h to have access to
the enum CLOSED_HALFSPACE.
public:   // Max added 2009-03-31
  typedef CGAL::Combine_with_halfspace<SNC_structure, SNC_point_locator>
          Combine_with_halfspace;
protected:     // Max added 2009-03-31
I need your help. Thank you, Peter.
B/Rgds
Max
Sent: Saturday, January 31, 2009 7:03 AM
To:
Hi Max,
I hoped that these were the patches that we did for you. These
were all patches that I wanted to do either way at some time
for CGAL 3.4. I guess that CGAL 3.4 will work nicely for you, as
everything works now fine with indexed_items. I even made the
indexed items the standard configuration, now. So, if you don't
specify the items, the indexed items will be used. Still, I can only
advice you to do the change slowly as suggested. I'll help you
if you have problems.
Peter
Attachment: COT1P.nef
Description: Binary data
  • RE: [cgal-discuss] CGAL 3.4 - Nef_3::intersection() problem, Max, 04/03/2009
