- To:
- Subject: Re: [cgal-discuss] Conforming triangulaions and kernels
- Date: Wed, 08 Apr 2009 17:17:54 +0200
- Organization: INRIA
Ben Supnik wrote:
The docs for make_conforming_Delaunay_2 say that it requires ConformingDelaunayTriangulationTraits_2. traits.
ConformingDelaunayTriangulationTraits_2 is labeled as having "Any model of Kernel concept. In particular, all CGAL kernels."
But...this doesn't seem correct to me - am I right in thinking that some CGAL exact pred exact construction kernels do not have sqrt? The one I was using did not, and I get a compile failure due to being unable to tkae the sqrt of a number.
If sqrt is indeed required and not in all kernels, is there a way to get an exact predicate/exact construction kernel without one of LEDA or GMP?
Known issue (to me at least).
One way to cheat is to define a sqrt() function for the number type
that you use, and make it approximate (convert to double, use std::sqrt,
and convert back). It might work for some/most rational number types,
and hopefully the algorithms won't break too much...
Sylvain Pion
INRIA Sophia-Antipolis
Geometrica Project-Team
CGAL, http://cgal.org/
- [cgal-discuss] Conforming triangulaions and kernels, Ben Supnik, 04/08/2009
- Re: [cgal-discuss] Conforming triangulaions and kernels, Sylvain Pion, 04/08/2009
- Re: [cgal-discuss] Conforming triangulaions and kernels, Fernando Cacciola, 04/08/2009
- Re: [cgal-discuss] Conforming triangulaions and kernels, avaxman, 04/08/2009
- Re: [cgal-discuss] Conforming triangulaions and kernels, Ben Supnik, 04/08/2009
