- To: <>
- Subject: RE: [cgal-discuss] Compiler doesn't identify "Triangulation_vertex_base_2"
- Date: Sat, 11 Apr 2009 16:19:02 +0300
I forgot to say that “EKernel”
is “simple_cartesian<CGAL::gmpq>” Amir. From: Amir Vaxman
[mailto:] Hello, I am trying to compile the following program. I get the
message: “error C2146: syntax error : missing ';' before identifier
'Vb' e:\meshtone\meshtone\dcel.h
26”, which seems like that for some reason the
“Triangulation_vertex_base_2” is not recognized. The relevant code parts: “ #include <CGAL/Triangulation_vertex_base_2.h> #include <CGAL/Exact_predicates_inexact_constructions_kernel.h> #include <CGAL/Constrained_Delaunay_triangulation_2.h> typedef
CGAL::Triangulation_vertex_base_2<EKernel>
Vb; typedef
CGAL::Constrained_triangulation_face_base_2<EKernel>
Fb; typedef
CGAL::Triangulation_data_structure_2<Vb,Fb>
TDS; typedef
CGAL::Constrained_Delaunay_triangulation_2<EKernel, TDS > CDT; “ I
have no idea why this error happens. I use CGAL 3.4 on a VS2005 compiler. Thanks, Amir. |
- [cgal-discuss] Compiler doesn't identify "Triangulation_vertex_base_2", Amir Vaxman, 04/11/2009
- RE: [cgal-discuss] Compiler doesn't identify "Triangulation_vertex_base_2", Amir Vaxman, 04/11/2009
- Re: [cgal-discuss] Compiler doesn't identify "Triangulation_vertex_base_2", Laurent Rineau (GeometryFactory), 04/14/2009
