cgal-discuss - Re: [cgal-discuss] Constraint Triangulation Face Base with info?
  • To:
  • Subject: Re: [cgal-discuss] Constraint Triangulation Face Base with info?
  • Date: Sun, 12 Apr 2009 14:14:01 +0300
I saw an example of inheriting a vertex base class to make a customized one.
However, I am not very proficient with what is needed to inherit a base class,
such as the constraint face base to include info. Can anyone supply a bit of
code to demonstrate how to inherit this class to include auxilary data?
Thanks,
Amir.
Quoting "Laurent Rineau (GeometryFactory)"
> On Saturday 11 April 2009 14:46:07 Amir Vaxman wrote:
> > Why is there only a class with info for vertices and faces of a
> > triangulation, but not constraint triangulation? How can I produce such
> > faces and vertices with info?
> You can use a Triangulation_vertex_base_with_info_n with a constrained
> triangulation.
> Laurent Rineau, PhD
> Engineer at GeometryFactory
> http://www.geometryfactory.com/
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
