RE: Solved! Re: Compiling the Polyhedron demo on Debian GNU/Linux Re: [cgal-discuss]
- To: <>
- Subject: RE: Solved! Re: Compiling the Polyhedron demo on Debian GNU/Linux Re: [cgal-discuss]
- Date: Tue, 14 Apr 2009 14:12:41 -0400
Parfait!
-----Original Message-----
[mailto:]
Sent: 14 avril 2009 13:57
To:
Subject: Solved! Re: Compiling the Polyhedron demo on Debian GNU/Linux Re:
[cgal-discuss]
Hi,
Finally it worked, using several cmake flags, as suggested by Joachim
Reichel in this same thread, and the CMakeLists.txt sent by Laurent
Rineau in a similar thread started by nomad421 in January.
Anyway, IMO cmake should make things easier, not harder.
Thanks and best regards,
-- A.
On Fri, Apr 3, 2009 at 3:02 AM, Laurent Rineau (GeometryFactory)
wrote:
> On Friday 03 April 2009 02:58:42 Alejandro Aguilar Sierra wrote:
>> I think so. The version I have installed in Debian Sid is 2.6.3:
>> ii cmake 2.6.3-2 A cross-platform, open-source make system
>> ii cmake-curses-gui 2.6.3-2 Curses based user interface for CMake
>> (ccmak ii cmake-data 2.6.3-2 CMake data files (modules, templates and
>> doc
> As I said in my previous email, CGAL cmake scripts, that were working well
> with cmake-2.6.1 (which was the more recent one when CGAL-3.4 has been
> release), do not work well with cmake-2.6.3. Kitware must have been broken a
> sort of compatibility in corner cases. One CGAL developer is currently
> having
> a look at that issue. The bug fix release CGAL-3.4.1 is delayed for that
> reason.
> Laurent Rineau, PhD
> Engineer at GeometryFactory http://www.geometryfactory.com/
> Also CGAL release manager: http://www.cgal.org/people.html
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
- Solved! Re: Compiling the Polyhedron demo on Debian GNU/Linux Re: [cgal-discuss], Alejandro Aguilar Sierra, 04/14/2009
- RE: Solved! Re: Compiling the Polyhedron demo on Debian GNU/Linux Re: [cgal-discuss], Mir Abolfazl Mostafavi, 04/14/2009
- [cgal-discuss] Getting different results..., panayiotis foteinos, 04/15/2009
- Re: [cgal-discuss] Getting different results..., Damian Sheehy, 04/15/2009
- Re: [cgal-discuss] Getting different results..., Andreas Fabri, 04/15/2009
- Re: [cgal-discuss] Getting different results..., Monique Teillaud, 04/15/2009
- Re: [cgal-discuss] Getting different results..., Andreas Fabri, 04/16/2009
- Re: [cgal-discuss] Getting different results..., panayiotis foteinos, 04/15/2009
- Re: [cgal-discuss] Getting different results..., Benjamin schwarz, 04/15/2009
