cgal-discuss - Re: [cgal-discuss] Using finger search with Delaunay Triangulation
  • To:
  • Subject: Re: [cgal-discuss] Using finger search with Delaunay Triangulation
  • Date: Sun, 19 Apr 2009 13:08:39 +0200
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=googlemail.com; s=gamma; h=mime-version:sender:in-reply-to:references:date :x-google-sender-auth:message-id:subject:from:to:content-type; b=R4Sz3tKGsuU9xAe/HHq6KIT143bpt0Dut6ikrGshANyrGM4YHkgLsUSK5WGpOCHX0y 912Vdv7GzoJVZ9kU1LDlUIZODlByGkuonjxExntSlzBO64VOjIdxX5sfGqSI763YxqTH EFkwsxwfmCQMRwndtGlIzqcwAc73aj7pwIPhA=
Hi Damian,
Sorry, this was me being stupid. I was accidently using a strange
patch (I did not write myself) to Triangulation_hierarchy_2.
However, I really appreciate your comprehensive answers. I also had a
look at Olivier Deviller's paper.
I am confident that I am now compiling against the official 3.4
release of CGAL. For some reason, however, the delaunay triangulation
is very close to the delaunay hierarchy in the queries and the
construction. I attached the benchmark program's source file for any
debunking.
Do the times make sense or would you expect the delaunay hierarchy
being faster than the delaunay triangulation?
Delaunay Hierarchy: finger query vs. non-finger query
n dt_build dt_no_finger dt_finger dt_speedup
dh_build dh_no_finger dh_finger dh_speedup
2 0.000011 0.404763 0.403647 1.002765
0.000002 0.405436 0.405328 1.000266
4 0.000009 0.089347 0.088662 1.007728
0.000004 0.088971 0.088810 1.001812
8 0.000012 0.041551 0.040761 1.019384
0.000007 0.041474 0.040800 1.016520
16 0.000025 0.164201 0.158971 1.032899
0.000016 0.165585 0.160771 1.029943
32 0.000032 0.069689 0.058045 1.200605
0.000031 0.069807 0.058301 1.197357
64 0.000068 0.089519 0.105669 0.847164
0.000070 0.089585 0.105138 0.852070
128 0.000138 0.117457 0.084255 1.394065
0.000136 0.092525 0.064825 1.427303
256 0.000286 0.118400 0.064962 1.822601
0.000290 0.118712 0.064920 1.828590
512 0.000559 0.140097 0.064911 2.158288
0.000572 0.140355 0.064893 2.162870
1024 0.001152 0.184033 0.081685 2.252957
0.001178 0.184366 0.081764 2.254856
2048 0.002357 0.249846 0.067586 3.696715
0.002420 0.249937 0.067444 3.705851
4096 0.004706 0.339099 0.073331 4.624231
0.004792 0.339403 0.073350 4.627173
8192 0.009519 0.470756 0.073420 6.411840
0.009998 0.470833 0.073425 6.412451
16384 0.019473 0.639252 0.066725 9.580394
0.020252 0.640028 0.066687 9.597512
32768 0.040319 0.907107 0.070604 12.847796
0.042462 0.899606 0.067399 13.347467
65536 0.082370 1.240469 0.067532 18.368593
0.087055 1.242859 0.069638 17.847420
131072 0.169797 1.758881 0.070463 24.961786
0.178655 1.756205 0.069502 25.268456
262144 0.345318 2.509199 0.071552 35.068168
0.362546 2.516872 0.072444 34.742214
524288 0.715394 3.665781 0.071931 50.962377
0.750623 3.674317 0.071780 51.188616
1048576 1.466444 6.713272 0.072994 91.970195
1.532415 6.730648 0.072908 92.317098
2097152 3.033258 15.357660 0.075456 203.531586
3.172991 15.327048 0.075358 203.390026
4194304 6.165663 30.508426 0.078001 391.128543
6.438287 30.560829 0.078401 389.802267
8388608 12.615620 52.426141 0.081205 645.603242
13.192613 52.019313 0.081088 641.516262
-- Manuel
2009/4/19 Damian Sheehy
> Hi Manuel,
> The Delaunay hierarchy is very fast search structure in and of itself,
> particularly if a start hint cannot be provided for each query. The purpose
> of the search hierarchy is to compute a good start location from which to
> walk. In your case you already have a very good starting location
> (Face_handle) for each query point. So why would you expect the search
> hierarchy to do anything for you? (Take a look at the paper: Google Olivier
> Devillers Delaunay hierarchy).
> You are not really leveraging functionality of the search hierarchy, but you
> are paying the overhead of building and maintaining it. Try your search
> without the hierarchy, providing the start hint as before. If that's not
> fast enough consider exploiting the structure of your problem; you know that
> your query points are distributed along a straight line. CGAL provides a
> very powerful function called a line walk that allows you to compute the set
> of triangles intersected by a line segment. It may help to take a close look
> at that. You may be able to set up an interval list from the line walk and
> replace your N queries by a single line walk plus a subsequent search for an
> interval.
> All the best!
> Damian
> On Sat, Apr 18, 2009 at 12:16 PM, Manuel Holtgrewe
> wrote:
>> Hi Damian,
>> Thank you for your answer.
>> I have written a little program with which I am trying to measure the
>> speedup that the fingers give me. The source code is attached, I
>> tested it with CGAL 3.4 on a machine with Intel Xeon processors
>> @2.3Ghz.
>> I get the following output:
>>         n      build  no_finger     finger    speedup
>>         2   0.000012   0.424343   0.425491   0.997302
>>         4   0.000018   0.086763   0.086414   1.004036
>>         8   0.000015   0.100489   0.099627   1.008651
>>        16   0.000033   0.114695   0.105578   1.086352
>>        32   0.000066   0.128658   0.123606   1.040871
>>        64   0.000134   0.135320   0.116303   1.163512
>>       128   0.000270   0.178627   0.143877   1.241526
>>       256   0.000539   0.174100   0.122833   1.417371
>>       512   0.001070   0.168988   0.150091   1.125904
>>      1024   0.002091   0.173133   0.160160   1.080999
>>      2048   0.004395   0.185442   0.175380   1.057372
>>      4096   0.008549   0.207307   0.195271   1.061638
>>      8192   0.017413   0.216792   0.208223   1.041154
>>     16384   0.033093   0.246830   0.232705   1.060700
>>     32768   0.067720   0.198592   0.188638   1.052769
>>     65536   0.135914   0.207161   0.195284   1.060819
>>    131072   0.281401   0.243547   0.232596   1.047081
>>    262144   0.561701   0.254221   0.240915   1.055233
>>    524288   1.137475   0.238146   0.225836   1.054509
>>   1048576   2.287607   0.250391   0.238223   1.051078
>>   2097152   4.772575   0.252274   0.239942   1.051396
>>   4194304   9.628133   0.282821   0.270887   1.044055
>>   8388608  19.543273   0.305526   0.292194   1.045627
>> As you can see, I could only measure very small speedups. I would
>> expect them to be much bigger. Am I doing something wrong?
>> -- Manuel
>> 2009/4/17 Damian Sheehy
>> > Hi Manuel,
>> > Based on visual inspection, your code looks correct. You do not have
>> > to special case the first nearest_vertex search; just pass a default
>> > Face_handle in the first iteration of the loop and start the loop from
>> > zero.
>> > Regards,
>> > Damian
>> > On 4/17/09, Manuel Holtgrewe
>> > wrote:
>> >> Hi,
>> >> I am trying to perform finger search with the delaunay hierarchy code
>> >> from CGAL. That is, I have a random point set which is added as the
>> >> points of a delaunay hierarchy / triangulation. Then, I have a list of
>> >> query points which lie along a line through this point set. I want to
>> >> query for the nearest neighbours of the points on the line.
>> >> This sequence of queries should offer good locality, i.e. if I know
>> >> the nearest neighbour x of point i on the line, the nearest neighbour
>> >> y of point i+1 should be very close to x. Thus, I am trying to use the
>> >> second parameter to Delaunay_triangulation_2::nearest_vertex(const
>> >> Point& p, Face_handle f= Face_handle()) const.
>> >> Will the following code do this, i.e. when calling x->face() (where x
>> >> is the nearest neighbour of the i-th query point i), will this return
>> >> a face adjacent to x and this helps to speed up the queries?
>> >> Thanks,
>> >> Manuel
>> >> // typedefs/aliases
>> >> struct K : CGAL::Exact_predicates_inexact_constructions_kernel {};
>> >> typedef CGAL::Triangulation_vertex_base_2<K>              Vbb;
>> >> typedef CGAL::Triangulation_hierarchy_vertex_base_2<Vbb>  Vb;
>> >> typedef CGAL::Triangulation_face_base_2<K>                Fb;
>> >> typedef CGAL::Triangulation_data_structure_2<Vb,Fb>       Tds;
>> >> typedef CGAL::Delaunay_triangulation_2<K, Tds>            Dt;
>> >> typedef CGAL::Triangulation_hierarchy_2<Dt>
>> >> Triangulation_hierarchy;
>> >> typedef Triangulation_hierarchy::Vertex_circulator
>> >> Vertex_circulator_hierarchy;
>> >> typedef Triangulation_hierarchy::Point
>> >>  Point_hierarchy;
>> >> Vertex_hierarchy;
>> >> typedef Triangulation_hierarchy::Vertex_handle
>> >> Vertex_hierarchy_handle;
>> >> typedef Triangulation_hierarchy::Face_handle
>> >> Face_hierarchy_handle;
>> >> void foo(const std::vector<Point_hierarchy> &points, const
>> >> std::vector<Point_hierarchy> &queries) {
>> >>  Triangulation_hierarchy dh;
>> >>   dh.insert(points.begin(), points.end());
>> >>   Vertex_hierarchy_handle v = dh.nearest_vertex(queries[0]);
>> >>   Face_hierarchy_handle f = v->face();
>> >>   for (int j = 1, jend = queries.size(); j < jend; ++j) {
>> >>     v = dh.nearest_vertex(queries[j], f);
>> >>     f = v->face();
>> >> You are currently subscribed to cgal-discuss.
>> >> To unsubscribe or access the archives, go to
>> >> https://lists-sop.inria.fr/wws/info/cgal-discuss
// File: test_dh_finger.cpp
// Author: Manuel Holtgrewe
#include <tr1/random>
#include <vector>
#include <CGAL/Circle_2.h>
#include <CGAL/Delaunay_triangulation_2.h>
#include <CGAL/Triangulation_hierarchy_2.h>
#include <CGAL/Real_timer.h>
// The Kernel we will use in our datastructures.
// Define some geometric primitive types.
typedef K::Circle_2 Circle;
typedef K::Vector_2 Vector;
// The datastructures for the Delaunay triangulation hierarchy.
typedef Triangulation_hierarchy::Point Point;
typedef Triangulation_hierarchy::Vertex Vertex;
typedef Triangulation_hierarchy::Vertex_handle Vertex_handle;
typedef Triangulation_hierarchy::Face_handle Face_handle;
const int seed = 42;
int main(int argc, char **argv)
std::tr1::mt19937 mt(seed);
int m = 1 << 16; // Number of queries.
printf("Delaunay Hierarchy: finger query vs. non-finger query\n");
printf("%10s %14s %14s %14s %14s %14s %14s %14s %14s\n", "n", "dt_build",
"dt_no_finger", "dt_finger", "dt_speedup", "dh_build",
"dh_no_finger", "dh_finger", "dh_speedup");
// Create the queries on a line (0, 0) to (1, 1).
std::vector<Point> queries;
for (int i = 0; i < m; ++i) {
double x = 1.0 * i / (m - 1);
queries.push_back(Point(x, x));
for (int k = 1; k <= 23; ++k) {
int n = 1 << k; // number of points
printf("%10d", n);
// Create points.
std::vector<Point> points;
for (int i = 0; i < n; ++i)
points.push_back(Point(1.0 * mt() / mt.max(), 1.0 * mt() / mt.max()));
// Delaunay triangulation.
Dt dt;
// Insert points into Delaunay triangulation.
CGAL::Real_timer timer;
timer.start();
dt.insert(points.begin(), points.end());
timer.stop();
printf(" %14f", timer.time());
// Perform queries without finger.
double no_finger_time;
timer.start();
for (int j = 0, jend = queries.size(); j < jend; ++j)
dt.nearest_vertex(queries[j]);
timer.stop();
no_finger_time = timer.time();
// Perform queries with finger.
double finger_time;
timer.start();
Vertex_handle v = dt.nearest_vertex(queries[0]);
Face_handle f = v->face();
v = dt.nearest_vertex(queries[j], f);
f = v->face();
timer.stop();
printf(" %14f", no_finger_time / finger_time);
// Delaunay hierarchy.
// Insert points into Delaunay hierarchy.
timer.start();
timer.stop();
timer.start();
dh.nearest_vertex(queries[j]);
timer.stop();
double finger_time;
timer.start();
Vertex_handle v = dh.nearest_vertex(queries[0]);
f = v->face();
timer.stop();
printf("\n");
return 0;
