cgal-discuss - Re: [cgal-discuss] Passing face_handles
  • To:
  • Subject: Re: [cgal-discuss] Passing face_handles
  • Date: Tue, 21 Apr 2009 23:38:51 +0000
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=pOQrbWhugrCRvD06WG9PNMh0JvCCg+6VpyvgDQFbC2MibDc7WXg3NqSwIqh/EH/kNK kqCqTebBbRf9ms504OkiIN1gZe5VEEhRqwQBLtbcRu2Y/N9Iz5JbR7a3fZ+t7/4a1Mkr oJ+hj+ryFQ/a/tPqEho/iY4TDvy5azxFM/7TM=
No the function didn't modify the triangulation in any way, it was just comparing triangles and their relative angles/orientation and I commented out everything but one line (so the debugger would have something to stop on) and still same weird issue. Simply passing the face_handle seems to screw it up, with using pointers being the only way I found to not have it change.
On Mon, Apr 20, 2009 at 8:08 AM, Laurent Rineau (GeometryFactory) <> wrote:
On Monday 20 April 2009 04:03:18 wrote:
> Hi all, I'm having issues with passing cgal objects and variables, ie when
> a valid face_handle is passed to a different function it suddenly changes
> all its values etc
> Face_handle current = surface[i], test = surface[i]->neighbor(j);//current
> and test are both fine
> CheckWall(current, test, &hazardType, &tested, &numTested);//inside
> CheckWall() their values are completely different
If your function CheckWall modifies the triangulation, handles to faces
may be modified (like iterators of a vector when you insert things in it).
Laurent Rineau, PhD
Engineer at GeometryFactory
http://www.geometryfactory.com/
