- To:
- Subject: [cgal-discuss] Re: 3D Boolean Operation failed on Union
- Date: Wed, 22 Apr 2009 12:09:38 -0700
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=ZIdwySOJZs7tjLVGw3qhfo+SBNkHISWWdH0F/tSBDcEW8wUD1SGEeYkjD6i/CovuYP s7/5jrefKMdhhb0G3Uxr7gzrJPP0zCGKwXg/BRwy2y0qbrfqpUhWLWiVsS19QOxhU/Aq +Ysd5bS+c6BwQYrz1VuH9bCcVoxuDypkjvqyc=
I can use try{} catch{} to catch the failure of boolean... but still don't know why it fails...
Joe
On Wed, Apr 22, 2009 at 10:45 AM, Joe C <> wrote:
Hi,
I have a failed case when running Nef_polyhedron_3 Union (or Join) Operation. I have two Nef_polyhedron_3 inputs : Nef_1.nef3 and Nef_2.nef3. Both Nef polyhdra are converted from Polyhedron_3 (closed and valid). CGAL crashes on performing Union of Nef_1 and Nef_2. Any ideas why it fails? Is there any mechanism in CGAL to catch the failure and avoid crashing the program?I tried to attach .zip files of Nef_1.nef3 and Nef_2.nef3, but not successful due to the limit of the file size(each file is about 1M). How do I transfer these files onto the forum or maybe CGAL people?
I am using CGAL 3.4 on Windows XP with Visual Studio 2008.
Thanks.
Joe
- [cgal-discuss] 3D Boolean Operation failed on Union, Joe C, 04/22/2009
- [cgal-discuss] Re: 3D Boolean Operation failed on Union, Joe C, 04/22/2009
- Re: [cgal-discuss] Re: 3D Boolean Operation failed on Union, Bart Janssens, 04/23/2009
