cgal-discuss - Re: [cgal-discuss] are vertex_handle from polyhedron and vertex_handle
  • To:
  • Subject: Re: [cgal-discuss] are vertex_handle from polyhedron and vertex_handle
  • Date: Thu, 23 Apr 2009 16:03:27 +0200
  • Organization: INRIA
Nizar Khalifa Sallem wrote:
Hi,
I was searching in the documentation and mailing list if Vertex_handle from polyhedron and Vertex_handle from triangulation were comparable I mean can I do this :
//assume declarations and includes done
Delaunay3::Vertex_handle dv;
Polyhedron P;
//assume creation done
for ( Vertex_iterator v = P.vertices_begin(); v != P.vertices_end(); ++v){
if (v == vd) {
//do something
but didn't found any entry, can someone help?
No, they are not comparable.
Delaunay and Polyhedron are totally different data structures in memory,
so why would you want to do this anyway ?
By the way are circulators and iterator around vertices comparable or not?
Within the same data structure, I believe these should be, yes.
At least they should both be convertible to the common corresponding
handle types. There could be some issues in particular cases though.
Sylvain Pion
INRIA Sophia-Antipolis
Geometrica Project-Team
CGAL, http://cgal.org/
