cgal-discuss - Re: [cgal-discuss] A bug when using a built-in number type-based
  • To:
  • Subject: Re: [cgal-discuss] A bug when using a built-in number type-based
  • Date: Wed, 29 Apr 2009 17:12:50 +0200
  • Organization: INRIA
BBB HHH wrote:
Hello,
I am using CGAL 3.4 release with VS2005 SP1 under Windows XP.
I used the join member function of the CGAL::Polygon_set_2<Kernel> class template with an exact Kernel (such as Simple_cartesian<CGAL::Gmpq>), my program works fine. But when i tried to use a built-in number type_based Kernel (i.e. the Kernel Simple_cartesian<double>) i had the following assertion.
CGAL error: precondition violation!
Expression : comp_f(object, parentP->object) != SMALLER
File : c:\program files\cgal-3.4\include\cgal\multiset.h
Line : 2128
Explanation:
Refer to the bug-reporting instructions at http://www.cgal.org/bug_report.html
CGAL error: assertion violation!
Expression : (m_statusLine.size() == 0)
File : c:\program files\cgal-3.4\include\cgal\sweep_line_2\basic_sweep_line_2_impl.h
Line : 232
Explanation:
I want to know if this is a CGAL bug or not and how to resolve it.
The CGAL code is not robust when you plug an inexact number type
like double. This is the infamous robustness probem (see the FAQ,
the web site...). So, don't use double.
Sylvain Pion
INRIA Sophia-Antipolis
Geometrica Project-Team
CGAL, http://cgal.org/
