cgal-discuss - RE: [cgal-discuss] Mesh simplification and generation with constraints
  • To: <>
  • Subject: RE: [cgal-discuss] Mesh simplification and generation with constraints
  • Date: Thu, 30 Apr 2009 10:47:19 +0300
Thanks! I will try that.
Amir.
-----Original Message-----
[mailto:]
Sent: Wednesday, April 29, 2009 8:39 PM
To:
Subject: Re: [cgal-discuss] Mesh simplification and generation with
constraints
Hello Amir,
> Hello,
> Is there a (simple) way to use CGAL mesh simplification and mesh
> generation with constraints? For both, the constraints mean that
> certain vertices and edge must exist in the mesh (not be simplified\be
> part of the generated mesh).
Attached there is a file "edge_collapse_constrained_polyhedron.cpp"
It contains a complete example showing how to mark edges as non-removable.
The trick is to supply a custom "edge_is_border" map which returns true for
edges which, even if they are not borders, should not be simplified.
That example will be added into the documentation.
Best
Fernando Cacciola
www.geometryfactory.com
