- To:
- Subject: Re: [cgal-discuss] Keep in Memory the initial triangle after insert_in_face
- Date: Mon, 04 May 2009 17:33:30 +0200
Hi Faniry,
Do you really want to implement our old Delaunay tree...?
You should be aware that CGAL proposes the Delaunay hierarchy, which is a more recent structure that speeds up point location in a Delaunay triangulation.
See
http://www.cgal.org/Manual/3.4/doc_html/cgal_manual/Triangulation_2_ref/Class_Triangulation_hierarchy_2.html#Cross_link_anchor_1172
The 3D version is also available in CGAL.
Best,
Monique Teillaud
wrote:
Hi all,
I built a structure for the Delaunay tree (DTree). My problem is the
following:
when I insert the first point (p1,p2), it works well, which means.
DTree.node = the big first triangle
DTree.child = {delta_1,delta_2,delta_3}
Now, when I insert the second point the location work well, suppose it is in
delta_3,
Now, I build a child for delta_3 using insert_in_face and incident_faces
Since, insert_in_face destruct delta_3, the delta_3 of DTree changes also. But
I want to keep it for the next location.
Is there a way to use insert_in_face and keep in an another memory the initial
face such us we can use it later on?
Regards
Faniry
- [cgal-discuss] Keep in Memory the initial triangle after insert_in_face, faniryharijaona, 05/04/2009
- Re: [cgal-discuss] Keep in Memory the initial triangle after insert_in_face, Monique Teillaud, 05/04/2009
- Re: [cgal-discuss] Keep in Memory the initial triangle after insert_in_face, razafindrazaka faniry harijaona, 05/04/2009
