cgal-discuss - Re: [cgal-discuss] Help Visualization
  • To:
  • Subject: Re: [cgal-discuss] Help Visualization
  • Date: Tue, 05 May 2009 09:15:33 +0200
Hi Leide,
All 2D demos use Qt, the older ones Qt3, the newer ones Qt4.
If you want to write your own demos you should have a look
at Qt4 based demos. For 2D they use the Qt GraphicsView framework.
For 3D they use libQGLViewer which is based on the OpenGL
widget that comes with Qt4.
http://www.cgal.org/Manual/3.4/doc_html/cgal_manual/GraphicsView/Chapter_main.html
http://doc.trolltech.com/4.4/graphicsview.html
http://www.libqglviewer.com/
The precompiled demos are part of the distribution, that is you
can take them as starting point for your own demos with a viewer.
Best regards,
andreas fabri
Leide wrote:
I installed cgal but need a viewer .. I never used libraries without viewer
own
... Friends indicated qt, but I do not know how to use ... I will develop a
software that will make the surface mesh with the tiangulation of 2D Delaunay
... I need a very viewer ... I Research on various pages including (cgal.org),
but without success ... I need a tutorial or help ..
Thank's
Leide
