- To:
- Subject: Re: [cgal-discuss] [REPOST] Why do I get precondition violation here
- Date: Thu, 14 May 2009 14:13:08 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:date :x-google-sender-auth:message-id:subject:from:to:content-type :content-transfer-encoding; b=KZkq+AjBo/lqtyc3yhVhZsGlgL9YON+VB6O1s9mFX0snyM4fQCmpR/0TO3hTwMx0QU SFVzJxuYmzvAWSlr3JZUJRallMr0HYDGKaeMl/apYSqs2tG1KN0iz+JWYAalqnMQU/+l pBZXKrSjpEif4+TvM7hdVbKX2XSge5z7inv+M=
Hi Damian , thank for you interest in my problem .
if it easier or more helpfull , I can attach my full project , just
let me know if needed
I had no problem until I introduced Circle arcs in my X_monotone curves.
typeDefs comes longer down for readability
void ReadPoly(std::istream& is,Polygon_2& pgn, std::string& nextPolyType)
XCurve curve;
std::list<XCurve> xcvs;
//some pseudo code begin
do
data<<new data from file
readSegment(data,curve);
xcvs.push_back(curve);
loop until no_more_lines.
//some pseudo code ends
pgn = Polygon_2 (xcvs.begin(), xcvs.end());
if (pgn.orientation()==CGAL::CLOCKWISE ) <<--failes -Precondition violation.
pgn.reverse_orientation();
void readSegment(std::string s, XCurve& curve)
int t;
readSegment_field(s,t);
switch (t)
case 0: { // line curvesegment
int sx,sy,ex,ey;
readSegment_line(s,sx,sy,ex,ey);
Point_2 ps = Point_2(sx,sy);
Point_2 pe = Point_2(ex,ey);
curve = XCurve(ps,pe);
};break;
case 1: { //arc curvesegment
int sx,sy,mx,my,ex,ey;
readSegment_arc(s,sx,sy,mx,my,ex,ey);
Point_2 ps = Point_2(sx,sy); //startpoint
Point_2 pm = Point_2(mx,my); //midpoint
Point_2 pe = Point_2(ex,ey); //endpoint
Curve c =Curve( ps,pm,pe);
curve =
XCurve(c.supporting_circle(),c.source(),c.target(),c.orientation(),0);
// curve = XCurve(ps,pe); // this did work perfect if used
instead of above line
};break;
case 2: {
};break;
} //switch
my typedefs :
typedef CGAL::Gmpq Base_nt;
typedef CGAL::Lazy_exact_nt<Base_nt> Coord_type;
struct Kernel : public CGAL::Cartesian<Coord_type> {};
typedef Kernel::Point_2 Point_2;
typedef Kernel::Circle_2 Circle;
typedef CGAL::Gps_circle_segment_traits_2<Kernel> Traits;
typedef Traits::Curve_2 Curve;
typedef Traits::X_monotone_curve_2 XCurve;
typedef Traits::Point_2 Circular_point_2;
typedef Traits::Polygon_2 Polygon_2;
best regards
kim
On Thu, May 14, 2009 at 2:06 PM, Kim Pedersen
> XCurve curve;
> do //some pseudo code
> loop until no_more_lines. //some pseudo code ends
> if (pgn.orientation()==CGAL::CLOCKWISE ) <<--failes here Precondition
> violation. , se below
> int t;
> switch (t)
> case 0: {
> int sx,sy,ex,ey;
> };break;
> case 1: {
> curve =
> };break;
> case 2: {
> };break;
> } //switch
> my typedefs :
> best regards
> kim
> On Thu, May 14, 2009 at 3:26 AM, Damian Sheehy
> wrote:
>> Hi Kim,
>> You need to provide more details. Which orientation test are you using?
>> CGAL::orientation(ForwardIterator,ForwardIterator)? It takes two arguments.
>> What is png - Portable Network Graphics?
>> Damian
>> On Wed, May 13, 2009 at 5:49 PM, Kim
>> wrote:
>>> Hi
>>> sorry ! this is a repost ,,, but I am really stopped.
>>> noone has any idear at all ? any clue is appreciated!
>>> I am sure the start and endpoint are the same ,, since if I input the
>>> same , just as linesegment then it works perfect.
>>> Why is the polygon below failing when
>>> trying to
>>> if (pgn.orientation()==CGAL::CLOCKWISE ) <-- fails with error , see
>>> below
>>> I can not see any thing wrong !!
>>> Polygon_2(
>>> (Circle_2(PointC2(1.74193e+006, 44602.1),
>>> 1.61312e+006,counterclockwise)) [1.74193e+006 43332 --> 1.7432e+006
>>> 44602]
>>> (Circle_2(PointC2(1.73489e+006, 44595.5),
>>> 6.90773e+007,counterclockwise)) [1.7432e+006 44602 --> 1.73847e+006
>>> 52099]
>>> (Circle_2(PointC2(1.73792e+006, 50955.1),
>>> 1.60508e+006,counterclockwise)) [1.73847e+006 52099 --> 1.73792e+006
>>> 52222]
>>> (Circle_2(PointC2(1.73792e+006, 50951.9),
>>> 1.61312e+006,counterclockwise)) [1.73792e+006 52222 --> 1.73665e+006
>>> 50952]
>>> (Circle_2(PointC2(1.73792e+006, 50952),
>>> 1.61415e+006,counterclockwise)) [1.73665e+006 50952 --> 1.73737e+006
>>> 49805]
>>> (Circle_2(PointC2(1.73491e+006, 44606.1), 3.31029e+007,
>>> clockwise))[1.73737e+006 49805 --> 1.74066e+006 44602]
>>> 1.61312e+006,counterclockwise)) [1.74066e+006 44602 --> 1.74193e+006
>>> 43332]
>>> CGAL error: precondition violation!
>>> Expression : cv1.point_position (p) == EQUAL && cv2.point_position (p) ==
>>> EQUAL
>>> File : c:\cgal\cgal-3.4\include\cgal\arr_circle_segment_traits_2.h
>>> Line : 249
>>> Explanation:
>>> Refer to the bug-reporting instructions at
>>> http://www.cgal.org/bug_report.html
>>> I did use this way to calc the the curves:
>>> curve =
>>> TIA
>>> Kim
>>> You are currently subscribed to cgal-discuss.
>>> To unsubscribe or access the archives, go to
>>> https://lists-sop.inria.fr/wws/info/cgal-discuss
- [cgal-discuss] Why do I get precondition violation here ?, Kim, 05/11/2009
- [cgal-discuss] [REPOST] Why do I get precondition violation here ?, Kim, 05/13/2009
- Re: [cgal-discuss] [REPOST] Why do I get precondition violation here, Damian Sheehy, 05/14/2009
- Message not available
- Re: [cgal-discuss] [REPOST] Why do I get precondition violation here, Kim, 05/14/2009
- Re: [cgal-discuss] [REPOST] Why do I get precondition violation here, Damian Sheehy, 05/15/2009
- Re: [cgal-discuss] [REPOST] Why do I get precondition violation here, Kim, 05/15/2009
- Re: [cgal-discuss] [REPOST] Why do I get precondition violation here, Bernd Gaertner, 05/14/2009
