- To:
- Subject: Re: [cgal-discuss] orientation compatibility of triangular facets
- Date: Thu, 14 May 2009 15:44:04 +0200
So how can man ensure that two facets are consistently oriented in a polyhedra surface or in a Delaunay3D triangulation?
Nizar SALLEM
Robotics and Artificial Intelligence PhD student
LAAS-CNRS
7, Avenue Colonel Roche
31077 Toulouse CEDEX 4
FRANCE
On May 14, 2009, at 3:19 PM, Andreas Fabri wrote:
Nizar Khalifa Sallem wrote:
So, if I pick any 2 adjacent facets in a Delaunay3D triangulation they will be consistently oriented?
No they will not. This is already due to the fact that a facet is a
std::pair<Cell_handle_int> which means that the facet can be seen
from different sides.
andreas
Nizar SALLEM
LAAS-CNRS
FRANCE
Hi,
Is there in CGAL a way to check if two triangular facets are orientation compatible in either Triangulation or Polyhedra modules ?
In a Triangulation_2 as well as in a Polyhedron faces are consistently oriented.
This is not the case for a Complex_2_in_triangulation_3, where facets
between tetrahedra can be marked as being part of the compex.
best regards,
andreas
Thanks.
Nizar SALLEM
LAAS-CNRS
FRANCE
- [cgal-discuss] orientation compatibility of triangular facets, Nizar Khalifa Sallem, 05/14/2009
- Re: [cgal-discuss] orientation compatibility of triangular facets, Andreas Fabri, 05/14/2009
- Re: [cgal-discuss] orientation compatibility of triangular facets, Nizar Khalifa Sallem, 05/14/2009
- Re: [cgal-discuss] orientation compatibility of triangular facets, Monique Teillaud, 05/14/2009
- Re: [cgal-discuss] orientation compatibility of triangular facets, Laurent Rineau (GeometryFactory), 05/14/2009
- RE: [cgal-discuss] orientation compatibility of triangular facets, Max, 05/15/2009
