- To:
- Subject: Re: [cgal-discuss] volumes in Nef_polyhedron_3
- Date: Sat, 16 May 2009 09:58:36 +0200
- Importance: Normal
- Sensitivity:
Hi Joe,
use the undocumented function
Nef_polyhedron_3::convert_inner_shell_to_polyhedron(SFace_const_iterator sf, Polyhedron& P)
Peter
-----Joe C <> wrote: -----use the undocumented function
Peter
To:
Date: 04/16/2009 07:29PM
Subject: [cgal-discuss] volumes in Nef_polyhedron_3
Hi,
I am using boolean operations provided by Nef_polyhedron_3 to union multiple polyhedra. The resultant Nef_polyhedron could be of multiple volumes. The documentation states that one can iterate all the volumes in Nef_polyhedron_3. Is it possilbe that each volume (or maybe the shell?) is converted to a sub - Nef_polyhedron_3 and then converted to Polyhedron_3? If CGAL does not have this function, what would be the best way to do it?
Thanks.
Joe
- Re: [cgal-discuss] volumes in Nef_polyhedron_3, Peter Hachenberger, 05/16/2009
- [cgal-discuss] Computing weighted medial axis with lower envelopes, avaxman, 05/16/2009
