Re: [cgal-discuss] A problem about writing the implicit surface mesh data to a ASCII file
- To:
- Subject: Re: [cgal-discuss] A problem about writing the implicit surface mesh data to a ASCII file
- Date: Mon, 18 May 2009 09:11:44 +0200
On Saturday 16 May 2009 04:19:00 weihy1984 wrote:
> Hello, everyone,
> I have a problem with the output of the implicit surface mesh data to a
> txt file. And my CGAL version is 3.3.1 of windows XP. At first, I want to
> get the number and coordinates of the vertices. Furthermore, I want to know
> the number of the triangles on the implicit surface and the indexes of
> three vertices of these triangles. So I add some output codes to 3d
> implicit surface mesh generation example in
> examples/Surface_mesher/mesh_an_implicit_function.cpp. But the result is
> not what I want. Many triangles I got were not on the surface. And I have
> spent four days to solve it, but there is no result. And I still don't know
> the reason why . I just be a cgal novice and I need your help very much,
> and I will appreciate it for your help very much. The following is my code,
> you can check the output part.
Your code seems correct. How many facets have you on that surface (a sphere),
with the criteria you have chosen?
Laurent Rineau, PhD
Engineer at GeometryFactory
http://www.geometryfactory.com/
- [cgal-discuss] A problem about writing the implicit surface mesh data to a ASCII file, weihy1984, 05/16/2009
- Re: [cgal-discuss] A problem about writing the implicit surface mesh data to a ASCII file, Laurent Rineau (GeometryFactory), 05/18/2009
- Re:Re: [cgal-discuss] A problem about writing the implicit surface, weihy1984, 05/18/2009
- Re: [cgal-discuss] A problem about writing the implicit surface, Laurent Rineau (GeometryFactory), 05/18/2009
