- To:
- Subject: Re: [cgal-discuss] implementing greedy delaunay with CGAL
- Date: Mon, 25 May 2009 10:00:16 +0200
wrote:
Hi all,
I have implemented, I hope faithfully, the Greedy Delaunay algorithm but I
am having troubles.
It appears that Delaunay Triangulation is never done the same way for the
same 3D points sample, that yields my implementation to give different
result at each run :(
Is there a way to fix the Delaunay Triangulation to make it give the same
result each time it is run?
Any ideas?
yes: use the CGAL Delaunay triangulation ;)
Monique Teillaud
- [cgal-discuss] implementing greedy delaunay with CGAL, nksallem, 05/23/2009
- Re: [cgal-discuss] implementing greedy delaunay with CGAL, Andreas Fabri, 05/25/2009
- Re: [cgal-discuss] implementing greedy delaunay with CGAL, Nizar Khalifa Sallem, 05/25/2009
- Re: [cgal-discuss] implementing greedy delaunay with CGAL, Monique Teillaud, 05/25/2009
