- To:
- Subject: Re: [cgal-discuss] how to read in Polygon in ascii format
- Date: Tue, 26 May 2009 16:02:41 +0300
Try to define:
typedef Base_nt Coord_ type;
instead of
typedef CGAL::Lazy_exact_nt<Base_nt> Coord_type;
wrote:
Hi I am very novice with cgal and have a very hard time with all this templates.
I got so far , that i got modified the" boolean_operations_2" example to fit
for me.
but when I join , I get some vertex totally wrong . http://i39.tinypic.com/vcvscj.jpg
I then would like to make a very small test app for bug reporting , but
struggle with reading back the ascii format again : (have appx 221 ) of this
kind
6 [62286 122530 --> 59786 125030]
[59786 125030 --> 48166 125030]
[48166 125030 --> 45666 122530]
[45666 122530 --> 48166 120030]
[48166 120030 --> 59786 120030]
[59786 120030 --> 62286 122530]
Polygon_2 p ;
instream >>p; // not possible since no >> avaible.
how to do ?? even my kernel supports circle , I only use segment for the moment.
Best regards
Buller
my type defs are : typedef CGAL::Gmpq Base_nt;
struct Kernel : public CGAL::Cartesian<Coord_type> {};
typedef Kernel::Segment_2 Segment;
typedef Kernel::Point_2 Point_2;
typedef Kernel::Circle_2 Circle;
typedef Kernel::Iso_rectangle_2 Iso_rectangle;
typedef CGAL::Gps_circle_segment_traits_2<Kernel> Traits;
typedef Traits::Curve_2 Curve;
typedef Traits::X_monotone_curve_2 XCurve;
typedef Traits::Point_2 Circular_point_2;
typedef Traits::Polygon_2 Polygon_2;
typedef CGAL::General_polygon_with_holes_2<Polygon_2> Polygon_with_holes;
typedef CGAL::General_polygon_set_2<Traits> Polygon_set;
typedef Polygon_with_holes::Hole_const_iterator Hole_const_iterator;
typedef CGAL::Polygon_2<Kernel> Linear_polygon_2;
typedef CGAL::Polygon_with_holes_2<Kernel> Linear_polygon_with_holes_2;
____ _ ____ _
/_____/_) o /__________ __ //
(____ ( ( ( (_/ (_/-(-'_(/
_/
- Re: [cgal-discuss] how to read in Polygon in ascii format, Efraim Fogel, 05/26/2009
