- To:
- Subject: Re: [cgal-discuss] install CGAL on unix sol86 platform
- Date: Mon, 1 Jun 2009 08:48:59 -0700 (PDT)
- Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; h=Message-ID:X-YMail-OSG:Received:X-Mailer:Date:From:Subject:To:MIME-Version:Content-Type; b=Ci+CXJGAu1LEJNaV4cX8PrM32O/urSPa+b3EhyBlxiDGVXV1PWXgDbBwTRDrM02MNpaVnI5KDDRJESj/rzGtpckJNRp6Cft4xC1QBoeOUqiV2RnfaQy1QwCV+WLnAVTJ3C6gF+uXoGd/bBOCqajTHyb4bFj2UQy5xjqYOXfq+Es=;
Hi Joachim,
I have to install CGAL 3.3 in order to be consistent with other platforms I have installed.
I tried to install CGAL 3.3 on the Unix i386_SunOS-5.10 with SUNPRO 5.90 compiler. I got compiler errors when I built CGAL Libraries. Please refer to attached log files. All the errors are pointed to config.h line 150. After looking at the code, I found that i386_SunOS-5.10 is not defined there. I am not sure if it is possible to modify that file on your side, so CGAL 3.3 can find the correct OS system. Thank you in advance.
Thanks,
-Shu
--- On Fri, 5/22/09, Joachim Reichel <> wrote:
compile.log
Description: Binary data
install.log
- Re: [cgal-discuss] install CGAL on unix sol86 platform, Shu Ye, 06/01/2009
- Re: [cgal-discuss] install CGAL on unix sol86 platform, Joachim Reichel, 06/01/2009
