cgal-discuss - Re: [cgal-discuss] How to find the intersection between a polygon and
  • To:
  • Subject: Re: [cgal-discuss] How to find the intersection between a polygon and
  • Date: Tue, 2 Jun 2009 16:07:47 +0800
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type:content-transfer-encoding; b=DcgvwpsGB99cRVjF9qimI8RwRkBUNqxAFX+4kROrc07ii/3BTj5oiocBgwUqjO4ntd ke0jwEKVsE2c+QO4pyFxqlTpuihfa/QnsU3PZc5j6M5j3urREK6Exed6QvBmsQ8pPcrq X+Jy0AYlynZITvZH2EERE4sWLcbLSzwfV3Hds=
On Sun, May 24, 2009 at 23:01, Dietrich Bollmann
wrote:
> What would be the best way to find the intersections between a polygon
> and a line segment?
>               o
>          o--+--o
>        / o-----o
>       o
If your polygon is convex, then you could decompose it into triangles
and intersect each triangle with the line segment using the
CGAL::intersection function:
<http://www.cgal.org/Manual/3.4/doc_html/cgal_manual/Kernel_23_ref/Function_intersection.html>
From the various intersection points & segments you would get, you
might have to sift out the 2 intersection points that lie on the
polygon boundary and connect them up to get the intersection segment.
~ash
  • Re: [cgal-discuss] How to find the intersection between a polygon and, Ashwin Nanjappa, 06/02/2009
