- To:
- Subject: Re: [cgal-discuss] iso-intensity surface from analyze image
- Date: Fri, 12 Jun 2009 16:01:06 +0200
wrote:
Hi all,
I am testing the example for skull meshing in CGAL. Surprisingly, I get
different node numbers for the surface when I run the example
mesh_a_3d_gray_image again and again. Does any one know what is going on? Does this mean if I use CGAL, I can't repeat my results in future? The version
I am running is 3.3.1.
Hi Yasheng,
The algorithm has some randomness in the initialization phase.
andreas
I also need a program to transfer images back and forth between .inr and .hdr
formats. I wonder whether any one can provide me such a program?
Appreciated!
Yasheng
- [cgal-discuss] iso-intensity surface from analyze image, chen.yasheng, 06/12/2009
- Re: [cgal-discuss] iso-intensity surface from analyze image, Andreas Fabri, 06/12/2009
- Re: [cgal-discuss] iso-intensity surface from analyze image, Dominik Szczerba, 06/12/2009
