cgal-discuss - Re: Re : [cgal-discuss] point inside surface / nearest cell
  • To:
  • Subject: Re: Re : [cgal-discuss] point inside surface / nearest cell
  • Date: Sat, 13 Jun 2009 13:04:27 +0200
Is the closest face guaranteed to contain the closest point? I think generally not...
-- Dominik
razafindrazaka faniry harijaona wrote:
May be it's not optimal but you can look for the nearest point and loop through the faces adjacent to this point and test which is the closest.
Regards
--- En date de : *Sam 13.6.09, Dominik Szczerba /<>/* a écrit :
De: Dominik Szczerba
Objet: [cgal-discuss] point inside surface / nearest cell
À:
Date: Samedi 13 Juin 2009, 9h49
Does CGAL provide the following functionality:
- robust point inside surface test (or at least fast (bbtree based
or something) robust intersection tests with triangles)
- I see a nearest point is available: is there a nearest face search
available as well?
with regards,
Dominik
-- You are currently subscribed to cgal-discuss.
