- To:
- Subject: Re: [cgal-discuss] Strange question on computing Power Diagram
- Date: Sun, 14 Jun 2009 08:17:41 -0700 (PDT)
You are right. The type of "sites" and "weight" in my program are both
"double". But if this is the reason of the problem, could you point out how
to solve it?
Thanks a lot!
Ophir Setter-2 wrote:
> The problem is probably that you use double representation of coordinate
> (like 1.0) which do not necessarily translate to a rational number (1/1)
> exactly.
View this message in context:
http://www.nabble.com/Strange-question-on-computing-Power-Diagram-tp23989082p24022654.html
- [cgal-discuss] Strange question on computing Power Diagram, Guodong Rong, 06/11/2009
- Re: [cgal-discuss] Strange question on computing Power Diagram, Ophir Setter, 06/13/2009
- Re: [cgal-discuss] Strange question on computing Power Diagram, redpearl, 06/14/2009
- <Possible follow-up(s)>
- [cgal-discuss] Strange question on computing Power Diagram, redpearl, 06/14/2009
