cgal-discuss - [cgal-discuss] Error with intersection in boolean set operations
  • To:
  • Subject: [cgal-discuss] Error with intersection in boolean set operations
  • Date: Mon, 22 Jun 2009 10:54:49 +0200
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:date:message-id:subject:from:to:content-type; b=lEq//5D8xWAoIDfa9H4iF0dmYNSOVoMV4BgqTo/hFEWXXQhBN5AUqI8E0NQgUwq8Qx KsbDUZykclFIPsD78LPGoiBkQtkqUvqi5j1GbaZKMOcmNSPS0fIP6No/ec2j26i4CGuJ y3VCFFo3JS8nmd/FHecL2kvheXte8FV3aNbLU=
Hi All,
I have the following error in the intersection  boolean set operation:
CGAL error: precondition violation!
Expr: cv1.point_position (p) == EQUAL && cv2.point_position (p) == EQUAL
File: C:\Archivos de programa\CGAL-3.3.1\include\CGAL/Arr_circle_segment_traits_
2.h
Line: 247
I have used a test program than compute a simple intersection as show in the figure
http://img241.imageshack.us/img241/7307/interseccion1.jpg
with this the program code:
#include "bso_rational_nt.h"
#include <CGAL/Simple_cartesian.h>
#include <CGAL/Gps_circle_segment_traits_2.h>
#include <CGAL/General_polygon_set_2.h>
#include <CGAL/General_polygon_with_holes_2.h>
#include <CGAL/Lazy_exact_nt.h>
#include <CGAL/squared_distance_2.h>
#include <CGAL/Object.h>
#include <CGAL/intersections.h>
#include <CGAL/Boolean_set_operations_2.h>
#include <CGAL/enum.h>
enum Sign { NEGATIVE, ZERO, POSITIVE};
typedef Sign  Orientation;
typedef CGAL::Simple_cartesian<double>                  Kernel;
typedef Kernel::Point_2                                 Point_2;
typedef Kernel::Circle_2                                Circle_2;
typedef Kernel::Line_2                                    Line_2;
typedef Kernel::Segment_2                          Segment_2;
typedef CGAL::Gps_circle_segment_traits_2<Kernel>       Traits_2;
typedef CGAL::General_polygon_set_2<Traits_2>           Polygon_set_2;
typedef Traits_2::Polygon_with_holes_2                  Polygon_with_holes_2;
typedef Traits_2::Curve_2                               Curve_2;
typedef Traits_2::X_monotone_curve_2                    X_monotone_curve_2;
typedef Traits_2::Point_2                                                 TPoint_2;
typedef Polygon_with_holes_2::General_polygon_2         Polygon_2;
int main (int argc, char * argv[])
  std::list<Polygon_2> polygons;
  Polygon_2 pgn;
  X_monotone_curve_2 s1(Point_2(449.268,624.272),Point_2(128.151,1180.46));
  pgn.push_back(s1);
  X_monotone_curve_2 s2(Point_2(128.151,1180.46),Point_2(-514.084,1180.46));
  pgn.push_back(s2);
  X_monotone_curve_2 s3(Point_2(-514.084,1180.46),Point_2(-835.202,624.272));
  pgn.push_back(s3);
  X_monotone_curve_2 s4(Point_2(-835.202,624.272),Point_2(-514.084,68.0801));
  pgn.push_back(s4);
  X_monotone_curve_2 s5(Point_2(-514.084,68.0801),Point_2(128.151,68.0801));
  pgn.push_back(s5);
  X_monotone_curve_2 s6(Point_2(128.151,68.0801),Point_2(449.268,624.272));
  pgn.push_back(s6);
  polygons.push_back (pgn);
  Polygon_2 pgn2;
  X_monotone_curve_2 r1(Point_2(101,2),Point_2(1,102));
  pgn2.push_back(r1);
  X_monotone_curve_2 r2(Point_2(1,102),Point_2(-99,2));
  pgn2.push_back(r2);
  X_monotone_curve_2 r3(Point_2(-99,2),Point_2(1,-98));
  pgn2.push_back(r3);
  X_monotone_curve_2 r4(Point_2(1,-98),Point_2(101,2));
  pgn2.push_back(r4);
  polygons.push_back (pgn2);
  std::list<Polygon_with_holes_2> res;
  // HERE IS THE ERROR
  CGAL::intersection (polygons.begin(), polygons.end(), std::back_inserter (res));
    std::copy (res.begin(), res.end(),
             std::ostream_iterator<Polygon_with_holes_2>(std::cout, "\n"));
  std::cout << std::endl;
  system("pause");
  return 0;
Otherwise I really want compute the intersection of polygons that support both circle and line segments. An test example is the next:
http://img5.imageshack.us/img5/9969/interseccion2.jpg
Polygon_2 construct_polygon (const Circle_2& circle)
  // Subdivide the circle into two x-monotone arcs.
  Traits_2 traits;
  Curve_2 curve (circle);
  std::list<CGAL::Object> objects;
  traits.make_x_monotone_2_object() (curve, std::back_inserter(objects));
  CGAL_assertion (objects.size() == 2);
  // Construct the polygon.
  Polygon_2 pgn;
  X_monotone_curve_2 arc;
  std::list<CGAL::Object>::iterator iter;
  for (iter = objects.begin(); iter != objects.end(); ++iter) {
    CGAL::assign (arc, *iter);
    pgn.push_back (arc);
  return pgn;
  std::list<Polygon_2> circles;
  Polygon_2 pgn;
  X_monotone_curve_2 s1(Point_2(88,49),Point_2(53,87));
  pgn.push_back(s1);
  X_monotone_curve_2 s2(Point_2(53,87),Point_2(3,101));
  pgn.push_back(s2);
  X_monotone_curve_2 s3(Point_2(3,101),Point_2(-46,89));
  pgn.push_back(s3);
  X_monotone_curve_2 s4(Point_2(-46,89),Point_2(-84,54));
  pgn.push_back(s4);
  X_monotone_curve_2 s5(Point_2(-84,54),Point_2(-98,4));
  pgn.push_back(s5);
  X_monotone_curve_2 s6(Point_2(-98,4),Point_2(-86,-45));
  pgn.push_back(s6);
  X_monotone_curve_2 s7(Point_2(-86,-45),Point_2(-51,-83));
  pgn.push_back(s7);
  X_monotone_curve_2 s8(Point_2(-51,-83),Point_2(-1,-97));
  pgn.push_back(s8);
  X_monotone_curve_2 s9(Point_2(-1,-97),Point_2(48,-85));
  pgn.push_back(s9);
  X_monotone_curve_2 s10(Point_2(48,-85),Point_2(86,-50));
  pgn.push_back(s10);
  X_monotone_curve_2 s11(Point_2(86,-50),Point_2(100,0));
  pgn.push_back(s11);
  X_monotone_curve_2 s12(Point_2(100,0),Point_2(88,49));
  pgn.push_back(s12);
  circles.push_back (pgn);
  circles.push_back (construct_polygon (Circle_2(Point_2(-192.967,624.272),  412465.795225)));
  CGAL::intersection (circles.begin(), circles.end(), std::back_inserter (res));
  system("pause");
  return 0;
With the same error
Can anybody help me ?   I already don´t know where it is the problem.
Thanks
Francisco
