cgal-discuss - Re: [cgal-discuss] minimum set of CGAL header files
  • To:
  • Subject: Re: [cgal-discuss] minimum set of CGAL header files
  • Date: Thu, 25 Jun 2009 09:34:30 +0800
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=Fmpw1062KUfYwdxKyJBPqe1Dl6w8JSLgoaOphe4asTNbEE5xQbbct6bkEqqDRzCqIu ROsnjPrERQipDeIDdcNe/KLt08uV8CAIqLE4Ec8HxiFNbzJ0r93qxrWg8icRtK621Ekd nAGZRmjfMQzsRTDnLpZzmsoa2XX1w9t6EqzrU=
Hi,
I think that's would be difficult to separate a minimum set header file because there are lot's of CGAL code is inline in header files.
2009/6/25 Joe C <>
Hi,
When installing CGAL package, it will install all the header files. I understand there are dependencies among these files. Is there any way to just install only "minimum set" header files (or what are the files that must be installed)? If any other files besides the "minimum set" are needed, they could be added in later. This will save storage and make the program clean.
Thanks.
Joe
