- To:
- Subject: Re: [cgal-discuss] CGAL+GMP and multithreading crash
- Date: Thu, 25 Jun 2009 09:49:36 +0200
- Organization: INRIA
Torchi Borchi wrote:
i would like to try mpq_class but:
#include <CGAL/gmpxx.h>
typedef mpq_class RT;
typedef CGAL::Cartesian<RT> K;
It should be correct.
this does not work.
Can you expand a bit on "it does not work" ?
how can use mpq_class to get a kernel?
i cant find any documentation or example.
i see also that #include <CGAL/gmpxx.h> is including
#include <gmpxx.h>
gmpxx.h is missing in CGAL-3.4-Setup.exe
i downloaded gmp-4.3.1 and added the path to gmpxx.h.
but i still dont know how to make a kernel out of mpq_class.
Note that you will also need to link against libgmpxx.
Sylvain Pion schrieb:
torchi borchi wrote:
i followed your suggestion and tried this:
typedef CGAL::Gmpq RT;
typedef CGAL::Simple_cartesian<RT> K;
but it still crashes. is Gmpq using reference counting?
Yes, it uses the same thread-unsafe mechanism.
i need exact constructions.
Try mpq_class instead of Gmpq ?
Or Quotient<MP_Float>, but that can be much slower.
Otherwise, someone needs to bite the bullet and fix
the reference counting mechanism (in <CGAL/Handle_for.h>).
Sylvain Pion
INRIA Sophia-Antipolis
Geometrica Project-Team
CGAL, http://cgal.org/
- [cgal-discuss] CGAL+GMP and multithreading crash, torchi.b, 06/24/2009
- Re: [cgal-discuss] CGAL+GMP and multithreading crash, Sylvain Pion, 06/24/2009
- <Possible follow-up(s)>
- Re: [cgal-discuss] CGAL+GMP and multithreading crash, torchi borchi, 06/24/2009
- Re: [cgal-discuss] CGAL+GMP and multithreading crash, Torchi Borchi, 06/24/2009
- Re: [cgal-discuss] CGAL+GMP and multithreading crash, Sylvain Pion, 06/25/2009
