cgal-discuss - RE: [cgal-discuss] About the surface mesh generator
  • To: <>
  • Subject: RE: [cgal-discuss] About the surface mesh generator
  • Date: Mon, 29 Jun 2009 13:52:17 +0300
Where do you specify initial points? I saw that Implicit_surface_3<Traits, Function> receives a bounding sphere.
Sent: Monday, June 29, 2009 12:58 PM
To:
Subject: Re: [cgal-discuss] About the surface mesh generator
yes, without any problem
The main point is that you should provide initial points
on each connected component if you want to be sure not
to miss one
Amir Vaxman wrote:
I am doing surface mesh generation from an implicit function. The zero level of the function is not necessarily a continuous surface (it can be several smooth closed surfaces). Does the surface mesh generator handle such cases?
Amir.
Mariette Yvinec
Geometrica project team
INRIA  Sophia-Antipolis
