- To:
- Subject: Re: [cgal-discuss] Non convex 2D mesh generation
- Date: Sat, 11 Jul 2009 16:36:05 +0800
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=fc4c29gaXHzNFHEX4y6wgQm+ZyvCAWyy0OMNpxQLnHiCAnyMud7UaaVN7DpBnE8ljJ AcYySAwqFVv4igCFkFA9q+c+x4IhtYP/s9UvQPJa4aonTE1Xis89mZLbIdAoZ/dd7QbU MedoTcDPK7GbnhvLmsHZ9R9JWPWB2aQFkYzfU=
Hi, Gil,
The boundary of CDT is convex one. U can use CGAL::Triangulation_2 to store/process the non-convex triangulation mesh.
best regards
shuchu
On Sat, Jul 11, 2009 at 12:38 AM, Gil Hoffer <> wrote:
Hi,
I'm working on some academic project, and I'd like to generate a 2D triangular mesh using the CGAL meshing package (with Constrained Delaunay Triangulation).
Unfortunately, when trying to create the mesh for a non-convex area, I get triangles which are outside the area I want to mesh (see attached image as example).
Is there a way to tell the meshing procedure not to do that?
thank you!
Gil
- [cgal-discuss] Non convex 2D mesh generation, Gil Hoffer, 07/10/2009
- Re: [cgal-discuss] Non convex 2D mesh generation, Shuchu Han, 07/11/2009
- Re:[cgal-discuss] Non convex 2D mesh generation, sanlington, 07/11/2009
- Re: [cgal-discuss] Non convex 2D mesh generation, Damian Sheehy, 07/11/2009
