- To:
- Subject: Re: [cgal-discuss] How to judge whether a point is an inner point
- Date: Wed, 15 Jul 2009 18:08:17 +0200
Dear all, be advised that GTS (GNU) implements this feature robustly.
--Dominik
On Wed, 2009-07-15 at 16:14 +0200, Pierre Alliez wrote:
> hi Yajun,
> do you mean that you have a triangle surface mesh represented eg as a
> CGAL polyhedron?
> if it is both boundary-free and intersection-free then yes - we are
> working (hopefully for the next release) on an AABB tree component which
> solves your problem.
> would you be interested in testing the component now? I could send it to
> you by email.
> Pierre Alliez
> INRIA Sophia Antipolis - Mediterranee
> Project-team GEOMETRICA
> http://www-sop.inria.fr/members/Pierre.Alliez/
> Tel: +33 4 92 38 76 77
> Fax: +33 4 97 15 53 95
> Yajun Wang a écrit :
> > Hi ALL,
> > I wonder if there are some functions in CGAL which could be used to judge
> > whether a given point is an inner point of a triangle model ?
> > And also are there some functions could be used to get the distance from
> > a given point to the boundary of a triangle model ?
> > Thank you !
> > Best regards,
> > Yajun Wang
- [cgal-discuss] How to judge whether a point is an inner point of a triangle model using CGAL, Yajun Wang, 07/15/2009
- Re: [cgal-discuss] How to judge whether a point is an inner point, Pierre Alliez, 07/15/2009
- Re: [cgal-discuss] How to judge whether a point is an inner point, Dominik Szczerba, 07/15/2009
