cgal-discuss - Re: [cgal-discuss] Polyhedral surface
  • To:
  • Subject: Re: [cgal-discuss] Polyhedral surface
  • Date: Thu, 23 Jul 2009 17:43:50 +0200 (CEST)
  • Importance: Normal
> Le jeudi 23 juillet 2009 01:47:52, Sascha Raesch a écrit :
>> Hi,
>> I'm trying to remesh a polyhedra by using the surface mesher.
>> To describe the polyhedra as a surface I wanted to use
>> Polyhedral_surface_3. But the associated header "Polyhedral_surface_3.h"
>> contains the following include:
>> #include <CGAL/Data_structure_using_octree_3.h>
>> This file doesn't exists at all.
>> I cannot find the file in the whole package.
>> Thanks in advance
> The files you are using are not documented.
> <CGAL/Data_structure_using_octree_3.h> is not shipped with CGAL and will
> never
> be. CGAL-3.4 has a better solution (and that will even be documented, with
> a
> stable API in CGAL-3.5). If you cannot wait for CGAL-3.5 (whose first beta
> release will be in less than two weeks), have a look at
> demo/Polyhedron/MainWindow_remeshing.cpp in CGAL-3.4.
> Laurent Rineau, PhD
> Engineer at GeometryFactory
> http://www.geometryfactory.com/
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
I tried to apply the solution of demo:
My code compiled to a program, but if I try to use this program then I get
the message
AABB_polyhedral_oracle: construct initial point set not implemented
The message is printed by the function CGAL::make_surface_mesh.
As far as I understand this problem, it is some functionality which
has not been implemented yet.
My question is whether I missed something or it is some functionality
which will be implemented.
