cgal-discuss - Re: [cgal-discuss] CGAL_NTS is_zero(den) with Delaunay Alpha-shapes
  • To:
  • Subject: Re: [cgal-discuss] CGAL_NTS is_zero(den) with Delaunay Alpha-shapes
  • Date: Fri, 24 Jul 2009 17:09:10 +0200
You are probably encountering a numerical problem
when computing the alpha_shape data structure....
Although the Delaunay triangulation is CGAL is granted not
to include tet with 0 volume, it may include tet with very small
(but non zero ) volume.
Everything works fine for the triangulation
because the kernel you are using provides exact predicates.
However, when you build an alpha-shapes, the critical alpha
values, which are squared_radius of minimum circumspheres
are computed. the EPIC kernel use floating point arithmetic
for that and may encounter numerical pb as a null denominator...
(The denominators in such computation are the volume of the tets).
A solution might be to use an exact kernel but
thiswill slow down your code.
cbamber85 wrote:
Hi all,
I'm creating a Delaunay alpha shape surface from a point cloud input. The
point cloud is generated from the surface of an existing mesh in another
program, so all the points lie on a surface in a very regular pattern with no
duplicate points (I clean the point cloud of them manually just in case). I
also make sure that there is at least 4 points to work with.
Here is the useful info:
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef CGAL::Alpha_shape_vertex_base_3<K> Vb;
typedef CGAL::Triangulation_hierarchy_vertex_base_3<Vb> Vbh;
typedef CGAL::Alpha_shape_cell_base_3<K> Fb;
typedef CGAL::Triangulation_data_structure_3<Vbh,Fb> Tds;
typedef CGAL::Delaunay_triangulation_3<K,Tds> Delaunay;
typedef CGAL::Triangulation_hierarchy_3<Delaunay> Delaunay_hierarchy;
typedef CGAL::Alpha_shape_3<Delaunay_hierarchy> Alpha_shape_3;
Delaunay_hierarchy dTet;
for (unsigned int i = 0; i < mPoints.length(); ++i){
dTet.insert(Point_3(mPoints[i].x, mPoints[i].y, mPoints[i].z));}
// At this line all is well, and I use the Delaunay hierarchy to instantiate
an
// Alpha_shape_3 object.
Alpha_shape_3 mesh(dTet);
// Which errors with this:
CGAL error: assertion violation!
Expression : ! CGAL_NTS is_zero(den)
File : C:\Program
Files\CGAL-3.4\include\CGAL/constructions/kernel_ftC3.h
Line :
No line number is given, but there is only one occurence of CGAL_NTS
is_zero(den) in the file and that is for calculating the determinant of a
matrix for the squared_radiusC3 function. However, for the alpha number I've
been supplying (what I think) is decent range of real numbers, all with the
same error. And I have also tried using the find_optimal_alpha function with
a
few low solid component numbers, again the same error.
I have seen others get this error in 2D for collinear points, but as I am
building my triangulation incrementally using Delaunay rules, I can't see how
the above is a possible outcome.
Does anybody have any suggestions?
Mariette Yvinec
Geometrica project team
INRIA Sophia-Antipolis
