- To:
- Subject: Re: [cgal-discuss] How can I cilp a line segment with an arbitrary polygon?
- Date: Sun, 26 Jul 2009 14:17:52 +0300
However, you can use the Arrangement_on_surface_2 package, the Boolean_set_operations_2 package is based on.
wrote:
Hi,--
The boolean set operations package supports regularized boolean operations and therefore does not supply the necessary tools for itersecting a line with a polygon at this time.
Best,
Guy
Quoting
Hello,
I'm new to cgal. I went through the content of the online manual and did some
googling and was not able find the answer.
I want to cut a line segment with an arbitrary polygon. How can I do it? Or
which part of the manual should I go back to read?
Thank you very much!
zhutq
____ _ ____ _
/_____/_) o /__________ __ //
(____ ( ( ( (_/ (_/-(-'_(/
_/
- [cgal-discuss] How can I cilp a line segment with an arbitrary polygon?, athena-blue, 07/26/2009
- Re: [cgal-discuss] How can I cilp a line segment with an arbitrary polygon?, guyzucke, 07/26/2009
- Re: [cgal-discuss] How can I cilp a line segment with an arbitrary polygon?, Efraim Fogel, 07/26/2009
