- To:
- Subject: Re: [cgal-discuss] How can I compile deom "Straight_skeleton_2" using Qt4
- Date: Sun, 26 Jul 2009 22:05:58 -0400
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:date :x-google-sender-auth:message-id:subject:from:to:content-type; b=ZGYuU8LxXNBfJXqIPDIhywGJm4edbpTGye4bdCW6v38KgWdCaPHO6WxgAVhG9jLQ49 ZPIQgp63TNFcR6dlrsplyN0g2+DVuwC+W6dOUad9qsoHc/K/yccsJPxk/zfRbumcy1pn g8YgKBpbWKp+9ORF4TEL19J+S8hXuDiniisnQ=
Hi I had the same problem few days ago. Are you using VS?
On Sun, Jul 26, 2009 at 9:10 PM, Quan <> wrote:
I successfully installed the CGAL, but when I want to build deom
"Straight_skeleton_2", I encounter some errors.
NOTICE: This demo requires CGAL and Qt3, and will not be compiled.
I install Qt4 in my pc.
How can I do?
Thank you very much.
- [cgal-discuss] How can I compile deom "Straight_skeleton_2" using Qt4, Quan, 07/27/2009
- Re: [cgal-discuss] How can I compile deom "Straight_skeleton_2" using Qt4, Federico Perazzi, 07/27/2009
- Re: Re: [cgal-discuss] How can I compile deom "Straight_skeleton_2" using Qt4, Quan, 07/27/2009
- Re: Re: [cgal-discuss] How can I compile deom "Straight_skeleton_2" using Qt4, Federico Perazzi, 07/27/2009
