cgal-discuss - [cgal-discuss] Construct Polyhedron from points
  • To:
  • Subject: [cgal-discuss] Construct Polyhedron from points
  • Date: Sun, 26 Jul 2009 23:29:26 -0700 (PDT)
Hello, Im trying to construct Polyhedron from my mesh structure. And then
NefPolyhedron from polyhedron. I found that I have to use Incremental
builder, but resulting polyhedron is_closed() is always false, even when my
mesh is simple cube. And NefPolyheron requires closed polyhedron, so is this
piece of code right? Or how do I create polyhedron from points?
template <class HDS> class PolyhedronFromMesh : public
CGAL::Modifier_base<HDS>
public:
PolyhedronFromMesh(const Mesh & mesh) : _mesh(mesh)
void operator()( HDS& hds)
// Postcondition: `hds' is a valid polyhedral surface.
CGAL::Polyhedron_incremental_builder_3<HDS> B( hds, false);
typedef typename HDS::Vertex Vertex;
typedef typename Vertex::Point Point;
unsigned int nPoints = _mesh.Points.size();
unsigned int nFacets = _mesh.Indices.size() ? _mesh.Indices.size()
/ 3 : nPoints / 3;
B.begin_surface(nPoints,nFacets);
for(unsigned int i = 0; i < nPoints; i++)
Vec3 p = _mesh.Points[i];
B.add_vertex(Point(p.x,p.y, p.z));
if(_mesh.Indices.size())
for(unsigned int i=0; i < _mesh.Indices.size(); i+=3)
B.begin_facet();
B.add_vertex_to_facet((long unsigned int)_mesh.Indices[i]);
B.add_vertex_to_facet((long unsigned int)_mesh.Indices[i+1]);
B.add_vertex_to_facet((long unsigned int)_mesh.Indices[i+2]);
B.end_facet();
else
B.begin_facet();
B.add_vertex_to_facet( i);
B.add_vertex_to_facet( i+1);
B.add_vertex_to_facet( i+2);
B.end_facet();
B.end_surface();
const Mesh & _mesh;
View this message in context:
http://www.nabble.com/Construct-Polyhedron-from-points-tp24674159p24674159.html
