- To:
- Subject: [cgal-discuss] instal cgal on windows
- Date: Fri, 31 Jul 2009 12:44:55 +0200 (CEST)
hi
please,help me to install cgal on windows,I don't configure cgal by cmake
,please help me.
erorr cmake is
CMake Error at CGAL/CMakeLists.txt:21 (hide_variable):
Unknown CMake command "hide_variable".
CMake Warning (dev) in CMakeLists.txt:
No cmake_minimum_required command is present. A line of code such as
cmake_minimum_required(VERSION 2.6)
should be added at the top of the file. The version specified may be lower
if you wish to support older CMake versions for this project. For more
information run "cmake --help-policy CMP0000".
This warning is for project developers. Use -Wno-dev to suppress it.
thanks
- [cgal-discuss] instal cgal on windows, se_mahdavi87, 07/31/2009
- Re: [cgal-discuss] instal cgal on windows, Laurent Rineau (GeometryFactory), 07/31/2009
- Re: [cgal-discuss] instal cgal on windows, sedigheh mahdavi, 07/31/2009
- <Possible follow-up(s)>
