[cgal-discuss] segmentation fault, 2D Delaunay triangulation, 3.4 and 3.5-beta1
- To:
- Subject: [cgal-discuss] segmentation fault, 2D Delaunay triangulation, 3.4 and 3.5-beta1
- Date: Fri, 31 Jul 2009 16:23:00 +0100
- Organization: OpenCFD Ltd.
Hello all,
I'm using a CGAL to do 2D Delaunay triangulation and I'm getting segmentation
faults triggered by the "orientation" function in "march_locate_2D" on line
1969 of Triangulation_2.h, called by me calling "insert" to add a new vertex.
The fault are not consistently reproducible - only appearing about 1 in 5-10
times that the executable is run. It happens with both the
Exact_predicates_exact_constructions_kernel and
Exact_predicates_inexact_constructions_kernel, and whether it is a debug
build
or not.
Compiling on linux x86_64, gcc 4.3.3 with -DFULLDEBUG -O0 options and boost
1.39.0, the error message is below and attached. I get the same result using
CGAL 3.4 and 3.5-beta1.
Any suggestions?
Best regards,
Graham Macpherson
#0 Foam::error::printStack(Foam::Ostream&) in
"/home/graham/OpenFOAM/OpenFOAM-dev/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::sigSegv::sigSegvHandler(int) in "/home/graham/OpenFOAM/OpenFOAM-
#2 ?? in "/lib64/libc.so.6"
#3 CGAL::Lazy<CGAL::Point_2<CGAL::Simple_cartesian<CGAL::Interval_nt<false>
>, CGAL::Point_2<CGAL::Simple_cartesian<CGAL::Gmpq> >, CGAL::Gmpq,
CGAL::Cartesian_converter<CGAL::Simple_cartesian<CGAL::Gmpq>,
CGAL::Simple_cartesian<CGAL::Interval_nt<false> >,
CGAL::NT_converter<CGAL::Gmpq, CGAL::Interval_nt<false> > > >::ptr() const at
~/OpenFOAM/ThirdParty-dev/CGAL-3.4/include/CGAL/Lazy.h:1161
#4 CGAL::Lazy<CGAL::Point_2<CGAL::Simple_cartesian<CGAL::Interval_nt<false>
CGAL::NT_converter<CGAL::Gmpq, CGAL::Interval_nt<false> > > >::approx() const
at ~/OpenFOAM/ThirdParty-dev/CGAL-3.4/include/CGAL/Lazy.h:1122
#5 CGAL::Point_2<CGAL::Lazy_kernel<CGAL::Simple_cartesian<CGAL::Gmpq>,
CGAL::NT_converter<CGAL::Gmpq, CGAL::Interval_nt<false> > > > >::AT const&
CGAL::Approx_converter<CGAL::Lazy_kernel<CGAL::Simple_cartesian<CGAL::Gmpq>,
CGAL::NT_converter<CGAL::Gmpq, CGAL::Interval_nt<false> > > >,
>::operator()<CGAL::Point_2<CGAL::Lazy_kernel<CGAL::Simple_cartesian<CGAL::Gmpq>,
>(CGAL::Point_2<CGAL::Lazy at kernel<CGAL::Simple_cartesian<CGAL::Gmpq>,
CGAL::NT_converter<CGAL::Gmpq, CGAL::Interval_nt<false> > > > > const&) const
#6 CGAL::Sign
CGAL::Filtered_predicate<CGAL::CartesianKernelFunctors::Orientation_2<CGAL::Simple_cartesian<CGAL::Gmpq>
CGAL::CartesianKernelFunctors::Orientation_2<CGAL::Simple_cartesian<CGAL::Interval_nt<false>
CGAL::Exact_converter<CGAL::Lazy_kernel<CGAL::Simple_cartesian<CGAL::Gmpq>,
CGAL::Simple_cartesian<CGAL::Interval_nt<false> > >,
true>::operator()<CGAL::Point_2<CGAL::Lazy_kernel<CGAL::Simple_cartesian<CGAL::Gmp
at >, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >,
CGAL::NT_converter<CGAL::Gmpq, CGAL::Interval_nt<false> > > > >,
>(CGAL::Point_2<CGAL::Lazy_kernel<CGAL::Simple_cartesian<CGAL::Gmpq>,
#7
CGAL::Triangulation_2<CGAL::Lazy_kernel<CGAL::Simple_cartesian<CGAL::Gmpq>,
CGAL::Triangulation_data_structure_2<CGAL::Triangulation_hierarchy_vertex_base_2<CGAL::indexedVertex<CGAL::Lazy_kernel<CGAL::Simple_cartesian<CGAL::Gmpq>,
CGAL::Triangulation_vertex_base_2<CGAL::Lazy_kernel<CGAL::Simple_cartesian<CGAL::Gmpq>,
CGAL::NT_converter<CGAL::Gmpq, CGAL::Interval_nt<false> > > at ,
CGAL::Triangulation_ds_vertex_base_2<void> > > >,
CGAL::indexedFace<CGAL::Lazy_kernel<CGAL::Simple_cartesian<CGAL::Gmpq>,
CGAL::Triangulation_face_base_2<CGAL::Lazy_kernel<CGAL::Simple_cartesian<CGAL::Gmpq>,
CGAL::Triangulation_ds_face_base_2<void> > > >
>::orientation(CGAL::Point_2<CGAL::Lazy_kernel<CGAL::Simple_cartesian<CGAL::Gmpq>,
#8
>::march_locate_2D(CGAL::CGALi::CC_iterator<CGAL::Compact_container<CGAL::indexedFace<CGAL::Lazy_kernel<CGAL::Simple_cartesian<CGAL::Gmpq>,
#9
>::locate(CGAL::Point_2<CGAL::Lazy_kernel<CGAL::Simple_cartesian<CGAL::Gmpq>,
#10
CGAL::Triangulation_hierarchy_2<CGAL::Delaunay_triangulation_2<CGAL::Lazy_kernel<CGAL::Simple_cartesian<CGAL::Gmpq>,
CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::NT_converter< at
CGAL::Triangulation_ds_face_base_2<void> > > > >
>::locate_in_all(CGAL::Point_2<CGAL::Lazy_kernel<CGAL::Simple_cartesian<CGAL::Gmpq>,
#11
>::insert(CGAL::Point_2<CGAL::Lazy_kernel<CGAL::Simple_cartesian<CGAL::Gmpq>,
#12 Foam::CV2D::insertPoint(Foam::Vector2D<double> const&, int) at
~/OpenFOAM/OpenFOAM-
dev/applications/utilities/mesh/generation/CV2DMesher/CV2DI.H:37
#13 Foam::CV2D::newPoints(double) at ~/OpenFOAM/OpenFOAM-
dev/applications/utilities/mesh/generation/CV2DMesher/CV2D.C:668
#14 main at ~/OpenFOAM/OpenFOAM-
dev/applications/utilities/mesh/generation/CV2DMesher/CV2DMesher.C:87
#15 __libc_start_main in "/lib64/libc.so.6"
#16 _start at
/usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/x86_64/elf/start.S:116
Segmentation fault
#6 CGAL::Sign
#7
#8
#9
#10
#11
~/OpenFOAM/OpenFOAM-dev/applications/utilities/mesh/generation/CV2DMesher/CV2DI.H:37
~/OpenFOAM/OpenFOAM-dev/applications/utilities/mesh/generation/CV2DMesher/CV2D.C:668
#14 main at
~/OpenFOAM/OpenFOAM-dev/applications/utilities/mesh/generation/CV2DMesher/CV2DMesher.C:87
#16 _start at
Segmentation fault
- [cgal-discuss] segmentation fault, 2D Delaunay triangulation, 3.4 and 3.5-beta1, Graham Macpherson, 07/31/2009
