cgal-discuss - Re: [cgal-discuss] instal cgal on windows
  • To:
  • Subject: Re: [cgal-discuss] instal cgal on windows
  • Date: Sat, 1 Aug 2009 05:07:03 -0700 (PDT)
  • Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; h=Message-ID:X-YMail-OSG:Received:X-Mailer:Date:From:Subject:To:In-Reply-To:MIME-Version:Content-Type; b=0gaDWez8EFPgekrUdz1t5h352UH0SIR86Oegr9AAX1cDFYKIoY0i830kNKZrIxdxIPjKb7YUqdyUl3ev8Knll0t1ZTGEaD5j40RsRKW40pdDttr44qNaiz/wRk+JtjXyIPJ4Xbjvcw54/aaco+B86rJ8D2FBJctCgd+4Ne4dbQQ=;
Hi
i instaled CGAL 3.1 easily
after copying its file i compiled CGAL libreari ( i think in Src directory) and then compile its example)
i use .Net 2003 for it
Regards
To:
Date: Saturday, August 1, 2009, 1:14 AM
hi
When I installed the CGAL-3.5-beta1, error occured ,the error is
"unabale to down load http://www.geometryfactory.com/cgal3.5/manual/cgal_manual.zip.error :file not found (404) " but continue instal ,After the installation I
configure cgal by cmake but  the error .
source directory="C:/CGAL-3.5-beta1/src"
binary directory=" C:/CGAL-3.5-beta1/src/CGAL"
red line in cmake-gui is :
CMAKE_INSTALL_PREFIX
LIBRARY_OUTPUT_PATH
CMAKE_BACKWARDS_COMPATIBILITY
CGAL_LIBRARY
THANKS.
To:
Date: Saturday, August 1, 2009, 6:33 AM
Le vendredi 31 juillet 2009 23:56:12, a écrit :
> hi all
> please help me,
> I using  CGAL-3.5-beta1 on windows vista , the error cmake repeat ,
> erorr cmake is
>  CMake Error at CGAL/CMakeLists.txt:21 (hide_variable):
>  Unknown CMake command "hide_variable"
> I instal cgal from instruction in adress
> http://acg.cs.tau.ac.il/cgal-at-tau/installing-cgal-and-related-programs-on
>-windows, erron in run section 5.2,please  help who install cgal on windows
> vista ?do instal cgal on windows vista?
> instal cgal for me very important.
> thanks.
What is your source directory, in cmake-gui?
What is your binary directory?
You should remove all files CMakeCache.txt that may have been created
incorrectly previously.
Laurent Rineau, PhD
Engineer at GeometryFactory
