- To:
- Subject: Re: [cgal-discuss] cmake static libs problem
- Date: Sat, 08 Aug 2009 20:11:34 +0200
Hi Matthias,
> I want to make a static build of CGAL 3.5 on a Linux machine. To do so the
> manual says to change the CMAKE_SHARED_LIBS=FALSE
> However it still builts shared libraries .so instead of .a !
> I can't find the flag with cmake-gui either. Is this a bug or where can I
> change the flag? I need a static libCGAL.a
it's a typo in the installation manual. BUILD_SHARED_LIBS=TRUE (see
INSTALL) should work (don't forget -D if you use the command line).
Joachim
- [cgal-discuss] cmake static libs problem, matthias.kunz, 08/07/2009
- Re: [cgal-discuss] cmake static libs problem, Joachim Reichel, 08/08/2009
