Hi
tanx for source code, but i could not run it.
i get som error such as ero in handle.h and
'finite_edges' : is not a member of 'CGAL::Constrained_Delaunay_triangulation_2<Gt>' with [ Gt=K ] i'm useing CGAL 3.1.
Please help me again.
tanx
--- On Sun, 8/2/09, sanlington <> wrote:
From: sanlington <> Subject: Re:[cgal-discuss] How to extract edges of a mesh To: "cgal-discuss" <> Date: Sunday, August 2, 2009, 5:40 PM
Hi ,Morteza Romoozi the edges in 2D mesh is hold implicitly,not like the face or the vertex,but you can access the coordinates of edges through the Face_handle and index. i pasted the example code from:http://www.cgal.org/Manual/3.5/doc_html/cgal_manual/Mesh_2/Chapter_main.html, and added some codes between the /****...**/ lines to show how to access edge's coordinates:
#include <CGAL/Exact_predicates_inexact_constructions_kernel.h> #include <CGAL/Constrained_Delaunay_triangulation_2.h> #include <CGAL/Triangulation_conformer_2.h>
#include <iostream>
typedef CGAL::Exact_predicates_inexact_constructions_kernel K; typedef CGAL::Constrained_Delaunay_triangulation_2<K> CDT; typedef CDT::Point Point; typedef
CDT::Vertex_handle Vertex_handle;
int main() { CDT cdt;
// construct a constrained triangulation Vertex_handle va = cdt.insert(Point( 5., 5.)), vb = cdt.insert(Point(-5., 5.)), vc = cdt.insert(Point( 4., 3.)), vd = cdt.insert(Point( 5.,-5.)), ve = cdt.insert(Point( 6., 6.)), vf = cdt.insert(Point(-6., 6.)), vg = cdt.insert(Point(-6.,-6.)), vh = cdt.insert(Point( 6.,-6.));
cdt.insert_constraint(va,vb); cdt.insert_constraint(vb,vc); cdt.insert_constraint(vc,vd); cdt.insert_constraint(vd,va); cdt.insert_constraint(ve,vf); cdt.insert_constraint(vf,vg); cdt.insert_constraint(vg,vh); cdt.insert_constraint(vh,ve);
std::cout << "Number
of vertices before: " << cdt.number_of_vertices() << std::endl;
// make it conforming Delaunay CGAL::make_conforming_Delaunay_2(cdt);
std::cout << "Number of vertices after make_conforming_Delaunay_2: " << cdt.number_of_vertices() << std::endl;
// then make it conforming Gabriel CGAL::make_conforming_Gabriel_2(cdt);
std::cout << "Number of vertices after make_conforming_Gabriel_2: " << cdt.number_of_vertices() << std::endl;
/******* you can access the coordinates of edges like this *******************************/ typedef CDT::Finite_edges_iterator FEit; typedef CDT::Edge Edge;
for
(FEit eit= cdt.finite_edges_begin(); eit!= cdt.finite_edges.end(); eit++ ) { Edge e= *eit; Point s= e.first->vertex((e.second+1)%3)->point(), t= e.first->vertex((e.second+2)%3)->point(); std::cout<<"s="<<s<<std::endl <<"t="<<t<<std::endl; } /********************************************************************/
在2009-08-02,"Morteza Romoozi" <> 写道:
Hi
i nead a mesher algorithm that mesh a terrain with excepted sites, and can deliver me edges of this mesh.
i visit below link but i dont know how to extract edges of the mesh
没有广告的终身免费邮箱,www.yeah.net
