- To:
- Subject: Re: [cgal-discuss] Dense 3D Reconstruction
- Date: Sat, 15 Aug 2009 21:09:39 +0530
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=NTIj9fNh0gZhbpgFktHeeALUAhchRp9kbO0DCSbcR8TNdSX/41WgOKgmxNlcSKsGlK eDivq6ud8BhYn4R1f4cUcXFpASDxj71gjSAkXahoVCiHEpJZztfnT3u4foawqzXLscG0 2kO4tP3W0JHD5xd7r+gOweiZD9bPc10LdrFQc=
Hello,
Thank you very much for the information. The link you sent seems useful.
I should be able to work something out with this.
Regards,
Indika
2009/8/15 Bo Zhou <>
Indika Tantrigoda wrote:
Hello,He,2009/8/14 Bo Zhou < <mailto:>>
Thanks for the reply. I'll have a look at chapter 34. I did however go through the link you mentioned.
The problem is that the methods given in the link such as Possion surface reconstruction and using Octrees require
the surface normals. But these are not available, only the x,y,z co-ordinates of the points which forms the point cloud.
Is there any method that can be used when the surface normals are not present to construct a mesh ???
Regards,
Indika
<http://www.cs.jhu.edu/%7Emisha/Code/>
Hello,
I am in the middle of a research where I try to reconstruct a
3D model based on photographs.
So far I am able to obtain a sparse point could containing the
points of the object. I have developed a point cloud
viewer in XNA to view this point cloud data.
What I would like to do is to generate a dense 3D model based
on this point could. Would this be possible with CGAL, if so
any advice would be very much appreciated.
I recently found out about CGAL and my knowledge in using CGAL
is very minimal (non actually).
Thanks in advance.
Regards,
indika
Hi,
It seems that you want to reconstruct mesh from point cloud, you
could have a look at
*Chapter 34 3D Alpha Shapes*
or
to find some useful implementation here
http://www.cs.jhu.edu/~misha/Code/
Thanks.
* Bo Zhou
* Blog : http://jedimaster.cnblogs.com
* Mobile : +86 13451813691
-- You are currently subscribed to cgal-discuss.
I think it's not difficult to generate per-vertex normal by CGAL, you can generate a KDTree then lookup several nearest neighbors to calculate the normal. I remember to use ANN library to do spatial search because the CGAL's implementation is not fast enough.
The RBF implicit surface reconstruction method does not require normal, but I have not found a public sources, you will see something useful in this thesis here,
http://www.labri.fr/perso/preuter/research/thesis/index.html
Thanks.
- [cgal-discuss] Dense 3D Reconstruction, Indika Tantrigoda, 08/13/2009
- Re: [cgal-discuss] Dense 3D Reconstruction, Bo Zhou, 08/14/2009
- Re: [cgal-discuss] Dense 3D Reconstruction, Indika Tantrigoda, 08/14/2009
- Re: [cgal-discuss] Dense 3D Reconstruction, Bo Zhou, 08/15/2009
- Re: [cgal-discuss] Dense 3D Reconstruction, Indika Tantrigoda, 08/15/2009
- Re: [cgal-discuss] Dense 3D Reconstruction, Andreas Fabri, 08/16/2009
- Re: [cgal-discuss] Dense 3D Reconstruction, Indika Tantrigoda, 08/16/2009
- Re: [cgal-discuss] Dense 3D Reconstruction, Nader Salman, 08/16/2009
- Re:Re: [cgal-discuss] Dense 3D Reconstruction, xihongshidelove666, 08/24/2009
- Re: Re: [cgal-discuss] Dense 3D Reconstruction, Indika Tantrigoda, 08/24/2009
