- To:
- Subject: Re: [cgal-discuss] CGAL installation problem with VS 2008 express edition
- Date: Mon, 17 Aug 2009 11:32:08 +0200
On Friday 14 August 2009 21:40:10 Ruqin Zhang wrote:
> Hi, I got a problem when I tried to use cmake (2.6.4) in CGAL installation.
> Before that, I already finished Boost (1.38) and Qt(4.5.2) installations.
Hi, that is a known problem that should be solved in CGAL-3.5-beta1 now.
If you are stuck with CGAL-3.4 for any reason, you can try to copy CGAL-3.5-
beta1/cmake/modules/FindBoost.cmake to CGAL-3.4/cmake/modules/.
Laurent Rineau, PhD
Release Manager of the CGAL Project
http://www.cgal.org/
R&D Engineer at GeometryFactory
http://www.geometryfactory.com/
- [cgal-discuss] CGAL installation problem with VS 2008 express edition, Ruqin Zhang, 08/14/2009
- Re: [cgal-discuss] CGAL installation problem with VS 2008 express edition, Kim, 08/15/2009
- Re: [cgal-discuss] CGAL installation problem with VS 2008 express edition, Atul Thakur, 08/15/2009
- Re: [cgal-discuss] CGAL installation problem with VS 2008 express edition, Laurent Rineau (GeometryFactory), 08/17/2009
