- To:
- Subject: Re: [cgal-discuss] Parameterization solver
- Date: Tue, 25 Aug 2009 09:59:55 +0200
Hi,
I used the parameterizer to parameterize a vertex with its first ring of neighbors (using default values). We are talking about 7 vertices in average. On a larger neighborhood the parameterizer worked fine. On this small neighborhood the default solver almost always complained it couldn't solve the system. Using the Tau solver it worked almost always - there was a time when it crashed during LU factorization - but there's a bigger problem: It took it almost a second to solve the system. This renders it to be impractical.
I think you should also add precompiled debug libraries of the tau solver. I understand it crashes much more than the release version, which makes it unusable, but at least I could compile my application in debug, and operate other parts of it. Adding the libraries would help me with unnecessarily clattering my code with #ifdefs.
Thanks.
Hi (again) Zohar,
CGAL 3.4 contains precompiled debug libraries of TAUCS and a few bug fixes in the parameterization code. Please try again with CGAL 3.4 in debug mode.
If the problem is still present, please post your code and input file to this
mailing list.
Best regards,
Laurent Saboret
INRIA Sophia-Antipolis
- [cgal-discuss] Parameterization solver, Zohar Levi, 08/24/2009
- Re: [cgal-discuss] Parameterization solver, Laurent Saboret, 08/25/2009
- Re: [cgal-discuss] Parameterization solver, Zohar Levi, 08/26/2009
- Re: [cgal-discuss] Parameterization solver, Zohar Levi, 08/27/2009
- Re: [cgal-discuss] Parameterization solver, Laurent Saboret, 08/27/2009
- Re: [cgal-discuss] Parameterization solver, Laurent Saboret, 08/28/2009
- Re: [cgal-discuss] Parameterization solver, Laurent Rineau (GeometryFactory), 08/28/2009
