cgal-discuss - Re: [cgal-discuss] Triangulation 2D - Vertex_circulator question
  • To:
  • Subject: Re: [cgal-discuss] Triangulation 2D - Vertex_circulator question
  • Date: Wed, 26 Aug 2009 17:24:40 +0200
Hi Lionel,
The look looks ok. What might be a problem is the remove_constrained_edge
during the loop.
It's a little bit like erasing an iterator in a list, and then do a ++ on it.
Does your loop also not work, when you just do a complete tour without
modifying the
triangulation.
What is vch.m_ptr.p->_p.base.base.elems
Do you get the same output, when you write std::cout << vch->point();
regards,
andreas
Lionel wrote:
Hello,
I am trying to use a vertex_circulator in a constraint delaunay triangulation.
An I obtain an infinite loop and I do not understand why...
I would like to turn around the Vertex_handle vh (to find the vertices that
are
the second vertex of the edges starting at vh).
I thought that it was a simple loop like this :
CDT::Vertex_circulator vc = m_cdt.incident_vertices(vh), done(vc);
do {
assert(m_cdt.is_valid());// to debug
Vertex_handle vch(vc); // to debug
[...] // my code to remove_constrained_edge when
needed
} while (++vc != done);
Maybe I did not understand what is a vertex circulator ?
Or is there an error in this code ?
I thought that the Vertex_circulator vc and the Vertex_handle vch built with
vc
are the same vertex. But in the debugger I have different coordinates... :
vch.m_ptr.p->_p.base.base.elems 0x0884f868
[0] 3.5743930654296299 double
[1] 0.57512286625400599 double
vc._v.m_ptr.p->_p.base.base.elems 0x0885cfd8
[0] 3.2727272017928222 double
[1] 1.6818181818181819 double
Did I miss something... ?
Thanks for your help,
Lionel
