- To:
- Subject: [cgal-discuss] Possible bug in Arrangement_on_surface_2::merge_edge (CGAL 3.4)
- Date: Fri, 28 Aug 2009 21:07:51 -0400
Hi Y'all,
I think I may have found either a bug or an unstated condition for merge_edge...
Merge_edge picks one of the two half-edge-pairs to become the new consolidated edge when an edge-pair is merged.
From what I can tell, Merge_edge never recalculates the "direction()" cached value on the halfedges.
But...in some cases, merging the edges (which are not required to be colinear - imagine merging two lines when the underlying curve type is "poly-line") might cause the direction of the "recycled" halfedge to change it's direction. This causes the planar map to be invalid.
I'm not sure my fix is so great...I'm using Arr_accessor's declaration of the dcel halfedge type to cast my way into the dcel, where I can flip the direction manually.
Bug? Design limitation? Is there a better work-around?
cheers
Ben
Scenery Home Page: http://scenery.x-plane.com/
Scenery blog: http://xplanescenery.blogspot.com/
Plugin SDK: http://www.xsquawkbox.net/xpsdk/
X-Plane Wiki: http://wiki.x-plane.com/
Scenery mailing list:
Developer mailing list:
- [cgal-discuss] Possible bug in Arrangement_on_surface_2::merge_edge (CGAL 3.4), Ben Supnik, 08/29/2009
- Re: [cgal-discuss] Possible bug in Arrangement_on_surface_2::merge_edge (CGAL 3.4), Ben Supnik, 08/29/2009
- Re: [cgal-discuss] Possible bug in Arrangement_on_surface_2::merge_edge (CGAL 3.4), efif, 08/29/2009
- Re: [cgal-discuss] Possible bug in Arrangement_on_surface_2::merge_edge (CGAL 3.4), efif, 08/31/2009
- Re: [cgal-discuss] Possible bug in Arrangement_on_surface_2::merge_edge (CGAL 3.4), Ben Supnik, 08/31/2009
