Re: [cgal-discuss] Trying to add info to a vertex in a segment Delaunay graph fails compilation
- To:
- Subject: Re: [cgal-discuss] Trying to add info to a vertex in a segment Delaunay graph fails compilation
- Date: Sat, 29 Aug 2009 09:51:15 +0300
It doesn't seem to work for the segment delaunay graph. Maybe the usual
triangulation vertex isn't enough..
Quoting Zohar Levi
> I didn't follow everything but it seems too complicated if you just wanted
> to
> add data to a vertex. You don't need to derive anything. I did something
> similar:
> typedef CGAL::Triangulation_vertex_base_with_info_2<int, Kernel> Vb;
> typedef CGAL::Triangulation_face_base_2<Kernel> Fb;
> typedef CGAL::Triangulation_data_structure_2<Vb,Fb> Tds;
> typedef CGAL::Delaunay_triangulation_2<Kernel, Tds> DT;
> typedef CGAL::Delaunay_triangulation_adaptation_traits_2<DT> AT;
> typedef CGAL::Delaunay_triangulation_caching_degeneracy_removal_policy_2<DT>
> AP;
> typedef CGAL::Voronoi_diagram_2<DT, AT, AP> VD;
> Maybe you should try first, just to use cgal basic vertex class with info,
> and just add an integer. If it works, in the worst case you could hold a
> pointer to your data there.
> ________________________________
> From:
> To:
> Sent: Friday, August 28, 2009 4:52:00 PM
> Subject: [cgal-discuss] Trying to add info to a vertex in a segment Delaunay
> Hello,
> I am trying to add information to a vertex in a SDG. For that matter, I took
> some code from the SDG demo and tryed to incorporate it, but obviously I am
> doing something wrong, because it doesn't compile. The code is:
> template < class Vbb, class Info_ >
> class Segment_Delaunay_graph_vertex_base_with_info_2
> : public Vbb
> public:
> // TYPES
> typedef Vbb Base;
> typedef Info_ Info;
> typedef typename Base::Storage_traits Storage_traits;
> typedef typename Base::Geom_traits Geom_traits;
> typedef typename Base::Site_2 Site_2;
> typedef typename Base::Storage_site_2 Storage_site_2;
> typedef typename Base::Data_structure Data_structure;
> typedef typename Data_structure::Face_handle Face_handle;
> typedef typename Data_structure::Vertex_handle Vertex_handle;
> template < typename DS2 >
> struct Rebind_TDS {
> typedef typename Vbb::template Rebind_TDS<DS2>::Other Vb2;
> typedef Segment_Delaunay_graph_vertex_base_with_info_2<Vb2,Info> Other;
> Segment_Delaunay_graph_vertex_base_with_info_2 () : Vbb(), info_() {}
> Segment_Delaunay_graph_vertex_base_with_info_2(const Storage_site_2& ss,
> Face_handle f)
> : Vbb(ss, f), info_() {}
> void set_info(const Info& info) { info_ = info; }
> const Info& info() const { return info_; }
> private:
> Info info_;
> struct SiteInfo{
> Number v;
> SiteInfo(){}
> typedef CGAL::Segment_Delaunay_graph_traits_without_intersections_2<Kernel>
> SDGTraits;
> typedef CGAL::Segment_Delaunay_graph_storage_traits_2<SDGTraits>
> ST;
> typedef CGAL::Segment_Delaunay_graph_vertex_base_2<ST>
> Vb;
> typedef CGAL::Segment_Delaunay_graph_vertex_base_with_info_2<Vb,SiteInfo>
> Vbi;
> typedef CGAL::Triangulation_face_base_2<SDGTraits>
> Fb;
> typedef CGAL::Triangulation_data_structure_2<Vbi,Fb>
> DS;
> typedef CGAL::Segment_Delaunay_graph_2<ST,DS>
> SDG;
> typedef SDG::Site_2
> SDGSite;
> typedef
> CGAL::Segment_Delaunay_graph_degeneracy_removal_policy_2<SDG>
> SDGPolicy;
> typedef
> CGAL::Segment_Delaunay_graph_adaptation_traits_2<SDG>
> SDGAdaptTraits;
> typedef CGAL::Voronoi_diagram_2<SDG,SDGAdaptTraits,SDGPolicy>
> VD;
> Thanks,
> Amir.
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
- [cgal-discuss] Trying to add info to a vertex in a segment Delaunay graph fails compilation, avaxman, 08/28/2009
- <Possible follow-up(s)>
- Re: [cgal-discuss] Trying to add info to a vertex in a segment Delaunay graph fails compilation, Zohar Levi, 08/29/2009
- Re: [cgal-discuss] Trying to add info to a vertex in a segment Delaunay graph fails compilation, avaxman, 08/29/2009
