cgal-discuss - Re:Re: [cgal-discuss] iterator circulator and handle
  • To: cgal-discuss <>
  • Subject: Re:Re: [cgal-discuss] iterator circulator and handle
  • Date: Tue, 1 Sep 2009 12:36:18 +0800 (CST)
hello Zohar Levi:
thanks for your reply. im just thinking about it ,i thought if i should iterate the list it will takes so much time ,so i want to know if there are direct way . thanks very much . 谢谢!
在2009-08-31,"Zohar Levi" <> 写道:
I didn't delve into this point and you should check my assumptions.
Up until now, I didn't have any problem treating a circulator as a handle, operating any functions of the handle on it. There suppose be a direct conversion from a circulator to a handle but you should check the declarations.
For the other way, I assume that a circulator is just a list of handles. So, if want to know the location of a handle in a list, you should iterate the list from the beginning. Then, no directly there.
That works fine for me, and I'm nor sure that you need more.
To: cgal-discuss <>
Sent: Sunday, August 30, 2009 3:38:18 PM
Subject: [cgal-discuss] iterator circulator and handle
hello
though i have used CGAL several weeks,im not so clear about the relation between iterators ,circulators and handles ,the problem is when i know the corresponding iterator or circulator how can i get the handle directly ,and when i know the handle how can i get the corresponding iterator and circulator directly . any one who can help thanks very much.
没有广告的终身免费邮箱,www.yeah.net
