cgal-discuss - [cgal-discuss] CGAL 3D Objects Intersections
  • To:
  • Subject: [cgal-discuss] CGAL 3D Objects Intersections
  • Date: Wed, 2 Sep 2009 05:15:21 -0700 (PDT)
Hello,
I made a simple testing program in order to check the intersection of two
spheres. I used a sphere with center in ( 0.5, 0.0, 0.0 ) and another sphere
with center in ( -0.5, 0.0, 0.0 ) and both radius 1.0. Then I tested if they
are intersected using the predicate CGAL::do_intersect() and it worked.
Next, I consider a second peer of two spheres first with center in ( 5.0,
0.0, 0.0 ) and the second with center in ( -5.0, 0.0, 0.0 ) and both radius
10.0 and test again if they are intersected using the same predicate
do_intersect() but in this case it doesn't work. Choosing in this way this
values i made a upscale of 10 times and it doesn't work. I mentioned that
the code was compiled with VS 2008 under Windows XP SP3.
Could you help me with this problem?
My source code follows:
#include "stdafx.h"
#include <CGAL/Cartesian.h>
#include <CGAL/Algebraic_kernel_for_spheres_2_3.h>
#include <CGAL/Spherical_kernel_3.h>
#include <CGAL/MP_Float.h>
#include <CGAL/Quotient.h>
typedef CGAL::Quotient< CGAL::MP_Float> NT;
typedef CGAL::Cartesian<NT> Linear_k;
typedef CGAL::Algebraic_kernel_for_spheres_2_3<NT> Algebraic_k;
typedef CGAL::Spherical_kernel_3<Linear_k,Algebraic_k> SK;
int main()
double r0 = 1.0;
SK::Point_3 sphereCenter00( 0.5, 0.0, 0.0 );
SK::Point_3 sphereCenter01( -0.5, 0.0, 0.0 );
SK::Sphere_3 s00( sphereCenter00, CGAL::MP_Float(r0) );
SK::Sphere_3 s01( sphereCenter01, CGAL::MP_Float(r0) );
if( CGAL::do_intersect( s00, s01 ) ){
std::cout<<"\n s00, s01 intersect \n";
}else{
std::cout<<"\n s00, s01 NOT intersect \n";
double r1 = 10.0;
SK::Point_3 sphereCenter10( 5.0, 0.0, 0.0 );
SK::Point_3 sphereCenter11( -5.0, 0.0, 0.0 );
SK::Sphere_3 s10( sphereCenter10, CGAL::MP_Float(r1) );
SK::Sphere_3 s11( sphereCenter11, CGAL::MP_Float(r1) );
if( CGAL::do_intersect( s10, s11 ) ){
std::cout<<"\n s10, s11 intersect \n";
}else{
std::cout<<"\n s10, s11 NOT intersect \n";
return 0;
View this message in context:
http://www.nabble.com/CGAL-3D-Objects-Intersections-tp25256322p25256322.html
