- To:
- Subject: Re: [cgal-discuss] CGAL::symmetric_difference error
- Date: Thu, 3 Sep 2009 21:40:45 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=CydSlt2OhtACApQmItrKbaaOPLcBx9hx2K9D1d58TZmsmKG8FnjDAY7EhWlD7DE/Yg ambcDXcIoSVCwx1YydjVHDM8D7VhFrpveNXIGHKQKMD2DHKNVZCdwf5D0WCIAVC939Qi atBKAb6Q5YilSzzC1pPsC1hJp8MGOMGvblkaI=
Thank you all, I solved the problem (to be sincere it's you who solved it!).
Laurent:
I did read some months ago the documentation about kernels and robustness (with those two links you poseted among that documentation). In that moment, I was just constructing some convex hulls and I thought that a inexact kernel would suit me, because my application is a real time one. I must confess that once I got what I was looking for I didn't keep on reading the documentation. Probably if I would have done I wouldn't had all these problems right now. And since then I just copied the typedefs when I needed them, without worrying if something had to be changed. But that's just my fault, all documentation I have read is quite well explained, so don't get frustrated about that.
Thank you a lot
- [cgal-discuss] CGAL::symmetric_difference error, Genís, 09/03/2009
- Re: [cgal-discuss] CGAL::symmetric_difference error, Bernd Gaertner, 09/03/2009
- Re: [cgal-discuss] CGAL::symmetric_difference error, Laurent Rineau (GeometryFactory), 09/03/2009
- Re: [cgal-discuss] CGAL::symmetric_difference error, Ben Supnik, 09/03/2009
- Re: [cgal-discuss] CGAL::symmetric_difference error, Genís, 09/03/2009
